Elementary Surfaces
The simplest of surfaces are the unbound planes. The next complexity are the second degree or quadric surfaces.
Non-degenerate Quadrics
Ellipsoid
x2 / a2 + y2 / b2 + z2 / c2 = 1                       (1)
a, b, c = intrinsic parameters
Sphere
Sphere, a special ellipsoid, can be expressed as
x2 + y2 + z2 = a2                            (2)
a = radius
Hyperboloid of one sheet
x2 / a2 + y2 / b2 - z2 / c2 = 1                            (3)
Hyperboloid of two sheets
x2 / a2 + y2 / b2 - z2 / c2 = -1                            (4)
Quadric Cone
x2 / a2 + y2 / b2 - z2 / c2 = 0                             (5)
Elliptic Paraboloid
x2 / a2 + y2 / b2 - 2 z = 0                                (6)
a, b = intrinsic parameters
Elliptic Cylinder
x2 / a2 + y2 / b2 = 1                                (7)
Cylinder
x2 + y2 = a2                                (8)
Hyperbolic Cylinder
x2 / a2 - y2 / b2 = 1                                 (9)
Parabolic Cylinder
y2- 2 l x = 0                             (10)
l = intrinsic parameters
Degenerate Quadrics
Parallel Planes
x2 - a2 = 0                             (11)
a = half the distance between the parallel planes
Intersecting Planes
x2 / a2 - y2 / b2 = 0                          (12)
tan-1 (b / a) = half the angle between the intersecting planes
Coincident Planes
x2 = 0                            (13)
Mathematics
Area of Intersecting Circles
Calculate area of intersecting circles
Area Units Converter
Convert between units of area.
Circle - the Chord Lengths when Divided in to Equal Segments
Calculate chord lengths when dividing the circumference of a circle into an equal number of segments.
Circles within a Rectangle - Calculator
Calculate the maximum number of circles within a rectangle - can be used to calculate the numbers of pipes or wires in a conduit or similar.
Elementary Curves
Ellipse, circle, hyperbola, parabola, parallel, intersecting and coincident lines.
Equal Areas - Circles vs. Squares
Radius and side lengths of equal areas, circles and squares.
Hyperbolic Functions
Exponential functions related to the hyperbola.
Polynomial Equation of nth Degree
The polynomial nth degree equation.
Spherical and Cylindrical Coordinates
3D cylindrical and spherical coordinate systems
