Electrical Motors - Speed vs. No. of Poles and Frequency
The speed at which an electric induction motor operates depends on
  • the input power frequency, and
  • the number of electrical magnetic poles
Speed (rpm)
PolesFrequency (50 Hz)Frequency (60 Hz)
SynchronousFull LoadSynchronousFull Load
2 3000 2850 3600 3450
4 1500 1425 1800 1725
6 1000 950 1200 1150
8 750 700 900 850
  • Slip - in synchronous electrical induction motors
Electrical
Electric Motors - Efficiency
Variable Frequency Drives - Heat Loss and Required Air Cooling
Avoid overheated variable frequency drives with adequate ventilation.
