Horizontal Drainage Pipe - Required Slopes
Drainage piping and recommended minimum slope or pitch:
Horizontal Drainage Pipes - Required Slopes
Pipe Diameter
(in)
Pitch
(in/ft)(m/m)Gradient
under 3 1/4 0.02 1:50
3 - 6 1/8 0.01 1:100
8 or larger 1/16 0.005 1:200
  • 1 in/ft = 0.083 m/m
Sanitary Drainage Systems
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
Cleanouts in Draining Systems
Cleanouts provides access to the sewer for rodding.
Drain Waste and Vent Pipes - Hanger Spacing
Support of Drain Waste and Vent - DWV - pipes.
Draining Systems - Main Vents
Vents in draining systems protects traps against pressure differences that could cause them to siphon or blow out .
Drains and Sewers - Capacities vs. Size
Drainage Fixture Units (DFU) connected to building drains and sewers.
Slope Calculator: Convert Between Degrees, Gradient, and Grade
Convert slopes pitch between degrees, gradients and grades.
Storm-Water Conductors
Roof drain capacities.
Storm-Water Runoff Coefficients vs. Surface
Storm-water runoff coefficients for various surfaces
Trap Sizes vs. Fixture Units
No. of fixture units and required trap size.
