Liquids - Critical Pressure Ratios
Critical pressure ratios for water:
Critical pressure ratios for liquids other than water:
Control Valve Sizing
Control Valves - Cavitation
Control valves and cavitation, application ratio and multi stage control valves.
Water Control Valves - Flow Coefficient Cv Diagram
Sizing of water control valves - Imperial units.
