Complex Numbers
There are two main forms of complex numbers
- Cartesian
- Polar
Complex numbers on the Cartesian form
A complex number consists of a real part and an imaginary part and can be expressed on the Cartesian form as
Z = a + jb (1)
Z = complex number
a = real part
jb = imaginary part (it is common to use i instead of j)
A complex number can be represented in a Cartesian axis diagram with an real and an imaginary axis - also called the Argand diagram:
Example - Complex numbers on the Cartesian form
The complex numbers
ZA = 3 + j2 (2a)
ZB = -3 + j3 (2b)
ZC = -2 - j2 (2c)
can be represented in the Argand diagram:
Addition and Subtraction of Complex numbers
Complex numbers are added/subtracted by adding/subtracting the separately the real parts and the imaginary parts of the number.
Example - Adding two Complex numbers
ZA = 3 + j2
ZB = -3 + j3
Z(A+B) = (3 + (-3)) + (j2 + j3)
= j5
Complex numbers on the Polar form
A complex number on the polar form can be expressed as
Z = r (cos(θ) + jsin(θ)) (3)
r = modulus (or magnitude) of Z - and is written as "mod Z" or |Z|
θ = argument (or amplitude) of Z - and is written as "arg Z"
r can be determined using Pythagoras' theorem
r = (a2 + b2)1/2 (4)
θ can be determined by trigonometry
θ = tan-1(b / a) (5)
(3) can also be expressed as
Z = r ejθ (6)
As we can se from (1), (3) and (6) - a complex number can be written in three different ways.
Example - Complex number on the Polar form
The complex number
Za = 3 + j2
can be expressed on the polar form by calculating the modulus and the argument.
The "modulus" can be calculated by using eq. (4):
r = (32 + 22)1/2
= 3.606
The "argument" can be calculated by using eq. (5):
θ = tan-1(2 / 3)
= 33.69o
The complex number on polar form (3):
Za = 3.606 (cos (33.69) + j sin( 33.69))
Or alternatively (6)
Za = 3.606 ej 33.69
Adding or Subtraction of Complex Numbers
Adding Complex Numbers
Za = a + jb
Zb = c + jd
Za + Zb = (a + jb) + (c + jd)
= (a + c) + j(b + d) (6)
or alternative
Za = ra (cos(θa) + jsin(θa))
Zb = rb (cos(θb) + jsin(θb))
Za + Zb = ra (cos(θa) + jsin(θa) + rb (cos(θb) + jsin(θb))
= (ra cos(θa) + rb cos(θb)) + j(ra sin(θa) + rb sin(θb)) (6b)
or alternatively
Za = ra ejθa
Zb = rb ejθb
Za + Zb = ra ejθa + rb ejθb
= (ra cos(θa) + rb cos(θb)) + j(ra sin(θa) + rb sin(θb)) (6c)
Example - Adding Complex Numbers
Za = 3 + j2
Zb = 5 - j4
Za + Zb = (3 + j2) + (5 - j4)
= (3 + 5) + j(2 + (-4))
= 8 - j2
Za = 3 (cos(35) + jsin(35))
Zb = 2 (cos(15) + jsin(15))
Za + Zb = (3 cos(35)+ 2 cos(15)) + j(3 sin(35) + 2 sin(15))
= 4.38 - j2.2
Subtracting Complex Numbers
Za = a + jb
Zb = c + jd
Za - Zb = (a + jb) - (c + jd)
= (a - c) + j(b - d) (7)
Example - Subtracting Complex Numbers
Za - Zb = 3 (cos(35) + jsin(35)) - 2 (cos(15) + jsin(15))
= (3 cos(35) - 2 cos(15)) + j(3 sin(35) - 2 sin(15))
= 0.52 + j1.2
Multiplication of Complex Numbers
Za = a + jb
Zb = c + jd
Za Zb = (a + jb) (c + jd)
= a c + a (jd) + (jb) c + (jb) (jd)
= a c + j(a d) + j(b c) + j2(b d) (8)
Since j2 = -1 - (8) can be transformed to
= (a c - b d) + j(a d + b c) (8b)
Example - Multiplying Complex Numbers
Za = 3 + j2
Zb = 5 - j4
Za Zb = (3 + j2) (5 - j4)
= (3 5 - 2 (-4)) + j(3 (-4) + 2 5)
= 23 - j2
Complex Conjugate
The complex conjugate of (a + jb) is (a - jb).
Multiplying a complex number with its complex conjugate results in a real number like
Za = a + jb
Za* = a - jb
Za Za* = (a + jb) (a - jb)
= a2 - j(a b) + j(a b) - j2b2
= a2 - (- b2)
= a2 + b2 (9)
Example - Multiplying a Complex Number with its Conjugate
Za = 3 + j2
Za* = 3 - j2
Za Za* = (3 + j2) (3 - j2)
= 32 + 22
= 13
Division of Complex Numbers
Division of complex numbers can be done with the help of the denominators conjugate:
Za = a + jb
Zb = c + jd
Za / Zb = (a + jb) / (c + jd)
= ((a + jb) / (c + jd)) ((c - jd) / (c - jd))
= (a c + j(a d) + j(b c) + j2(b d)) / (c2 + d2) (10)
Multiplying both the nominator and the denominator with the conjugate of the denominator is called rationalizing.
• Mathematics
AC - Active, Reactive and Apparent Power
Real, imaginary and apparent power in AC circuits.
Algebraic Expressions
Principal algebraic expressions formulas.
Decimal System Prefixes
Prefix names used for multiples and submultiples units.
Designation of Large Numbers
Designation of large number in US vs. other countries.
Differential Calculus
Derivatives and differentiation expressions.
Fractions
Law of fractions
Hyperbolic Functions
Exponential functions related to the hyperbola.
Polar vs. Cartesian Coordinates
Convert between Cartesian and Polar coordinates.
Radians vs. Degrees - Definition and Conversions
Roman Numerals
Roman numerals are a combinations of seven letters.
Square and Cube Roots of Numbers – Reference Table
Comprehensive table of square and cube roots for various numbers.
Triangle
Triangle analytical geometry.
Trigonometric Functions
Sine, cosine and tangent - the natural trigonometric functions.
Vector Addition
Online vector calculator - add vectors with different magnitude and direction - like forces, velocities and more.
