Combustion Processes and Combustion Efficiency
Combustion is an exothermic reaction between a fuel and an oxidant.
Combustion of carbon and oxygen to carbon dioxide can be expressed as:
C + O2 > CO2
Combustion of methane and oxygen to carbon dioxide and water can be expressed as:
CH4 + 2 O2 > CO2 + 2 H2O
Combustion of hydrogen and oxygen to water can be expressed as:
H2 + 1/2 O2 > H2O
Typical combustion process efficiency can be summarized to
- home fireplace: 10 - 40 %
- space heater: 50 - 80 %
- residential gas furnace with low efficiency atmospheric burner: 70 - 80 %
- oil burner heating system: 70 - 85 %
- gas powered boiler: 75 - 85 %
- high efficiency gas or oil condensing furnace: 85 - 95 %
Furnace Performance Indices
The performance of a furnace is usually assessed by the following indices
Thermal Efficiency
μt = 100 Eo / Ei (1)
μt = thermal efficiency
Eo = energy output (W, Btu/h)
Ei = fuel energy input (W, Btu/h)
Annual Fuel Utilization Efficiency - AFUE
AFUE measures the annual amount of heat actually delivered compared to the amount of fuel supplied to the furnace.
AFUE = 100 Eao / Eai (2)
AFUE = annual fuel utilization efficiency
Eao = annual energy output (W, Btu/h)
Eai = annual fuel energy input (W, Btu/h)
Steady-state Efficiency - SSE
Steady State Efficiency measures how efficiently a furnace converts fuel to heat once the furnace has warmed up and is running steadily and can be expressed as
SSE = 100 (Ei - El) / Ei (3)
SSE = steady-state efficiency
El = energy loss (W, Btu/h)
• Combustion
Boiler - Efficiency
Combustion gross and net calorific value.
Boilers - Classification
Classification of boilers according the ASME Boiler and Pressure Vessel Code.
Combustion Heat
Combustion Testing
Combusting testing of fuel oil and gas burners.
Heating Values of Fuel Gases
Combustion heat values for gases like acetylene, blast furnace gas, ethane, biogas and more - Gross and Net values.
Optimal Combustion Processes - Fuel vs. Excess Air
Stable and efficient combustion requires correct mixture of fuels and oxygen.
