Centripetal and Centrifugal Acceleration Force
Centripetal and Centrifugal Force are the action-reaction force pair associated with circular motion.
Centripetal Acceleration
Velocity is a vector - specifying how fast (or slow) a distance is covered and the direction of the movement. Since the velocity vector (the direction) of a body changes when moved in a circle - there is an acceleration.
This  acceleration is named the centripetal acceleration - and can be expressed as
ac = v2 / r
= ω2 r
= (2 π nrps )2 r
= (2 π nrpm / 60)2 r
(π nrpm / 30)2 r                             (1)
ac = centripetal acceleration (m/s2, ft/s2)
v = tangential velocity (m/s, ft/s)
r = circular radius (m, ft)
ω = angular velocity ( rad /s)
nrps = revolutions per second (rev/s, 1/s)
nrpm = revolutions per min (rev/min, 1/min)
Centripetal Force
According Newton's second law the centripetal force can be expressed as
Fc = m ac
= m v2 / r
= m ω2 r
= m (2 π ns )2 r
= m (2 π nrpm / 60)2 r
= m (π nrpm / 30)2 r                           (2)
Fc = centripetal force (N, lbf)
m = mass (kg, slugs)
According to Newton's Third Law the centripetal force acting on the object has a centrifugal force of the same magnitude acting in the opposite direction.
Example - the Centripetal Acceleration and Force acting on a Car through a Curve
Metric Units
A car with mass 1000 kg drives through a curve with radius 200 m at speed 50 km/h. The centripetal acceleration can be calculated as
ac = ((50 km/h) (1000 m/km) (1/3600 h/s))2 / (200 m)
= 0.965 m/s2
= 0.1 g
1 g = acceleration of gravity (9.81 m/s2)
The centripetal force can bee calculated as
Fc = (1000 kg) ( 0.965 m/s2)
= 965 N
= 0.97 kN
Related to the gravity force - weight :
Fg = (1000 kg) (9.81 m/s2)
= 9810 N
= 9.8 kN
Imperial Units
A car with weight (gravity force) 3000 lb travels through a curve with radius 100 ft with speed 15 miles/h .
The mass of the car can be calculated as
m = (3000 lb) / (32 ft/s2)
= 94 slugs
ac = ((15 miles/h)(5280 ft/mile) / (3600 s/h))2/ (100 ft)
= 4.84 ft/s2
Fc = (94 slugs) (4.84 ft/s2)
= 455 lbf
Centripetal (Centrifugal) Calculator - velocity
This calculator can be used if the velocity of an object is known - like a car in a turning curve.
Centripetal (Centrifugal) Force - rpm
Equation (2) can be modified to express centripetal or centrifugal force as a function of revolution per minute - rpm - as
Fc = 0.01097 m r nrpm                      (3)
nrpm = revolution per minute (rpm)
Centripetal (Centrifugal) Calculator - rpm
This calculator can be used if revolution speed of an object is known - like a turning bowl in a lathe.
Centrifugal Force
Force is an abstraction representing the push and pull interaction between objects.  Newton's third law states that
  • for every acting force there is an equal and opposite reaction force
Therefore there must be an equal and opposite reaction force to the Centripetal Force - the Centrifugal Force.
Dynamics
Mechanics
Acceleration
Change in velocity vs. time used.
Acceleration of gravity and Newton's Second Law - SI and Imperial units.
Acceleration Units Converter
Converting between units of acceleration.
Banked Turn
A turn or change of direction in which the vehicle banks or inclines, usually towards the inside of the turn.
Car - Required Power and Torque
Power, torque, efficiency and wheel force acting on a car.
Car Acceleration
Car acceleration calculator.
Car Fuel Consumption - liter/100 km
Calculate fuel consumption in liter per km - consumption chart and calculator.
Conn-Rod Mechanism
The connecting rod mechanism.
Conservation of Momentum
The momentum of a body is the product of its mass and velocity - recoil calculator.
Distance Traveled vs. Speed and Time - Calculator and Chart
Velocity plotted in time used diagram.
Driving Distances between European Cities
Driving distance between some major European cities.
Equilibrant Force
The force required to keep a system of forces in equilibrium.
Force
Force Ratio
The force ratio is the load force versus the effort force.
Fuel Consumption - mpg
Calculate fuel consumption in miles per gallon - mpg - calculator and consumption charts.
New vs. Old Car Costs: A Comprehensive Cost Comparison
Compare the total cost of owning a new car versus an old car, including purchase price, maintenance, fuel efficiency, insurance, and depreciation. Use our detailed breakdown to make an informed financial decision before buying the next vehicle.
Piston Engines - Compression Ratios
Cylinder volume and compression ratios in piston engines.
Projectile Range
Calculate the range of a projectile - a motion in two dimensions.
Rolling Resistance
Rolling friction and rolling resistance.
Rotating Bodies - Stress
Stress in rotating disc and ring bodies.
Vehicle - Distance Traveled vs. Velcocity and Time Used (mph)
Speed (mph) and time (hours) and distance traveled (miles) chart.
Vehicle - Distance Traveled vs. Velocity and Time (km/h)
Speed (km/h) vs. time (hours) and distance traveled (km).
Vehicles Traffic Flow and Density
Traffic flow and density as used in highway design.
