12 Volt - Amps Amps vs. Wire Gauge: Choosing the Right Wire Size
Conductors in electrical systems should not be sized with voltage drops exceeding 3%.
For a 12V system the maximum voltage drop should be less than (12 V) x 3% = 0.36 V.
Conductor sizes (AWG) related to maximum current through a 12V electrical copper wire and length of cable - are indicated below:
American Wire Gauge (#AWG)
Length
(feet)
Maximum Current (amps)
5101520253040506070
15 16 12 10 10 8 8 6 6 4 4
20 14 12 10 8 8 6 6 4 4 4
25 14 10 8 8 6 6 4 4 2 2
30 12 10 8 6 6 4 4 2 2 2
40 12 8 6 6 4 4 2 2 1 1/0
50 10 8 6 4 4 2 2 1 1/0 1/0
60 10 6 6 4 2 2 1 1/0 2/0 2/0
70 10 6 4 2 2 2 1/0 2/0 2/0 3/0
80 8 6 4 2 2 1 1/0 2/0 3/0 3/0
90 8 4 4 2 1 1/0 2/0 3/0 3/0 4/0
Note! Failure to use an adequate size may result in a fire. Always secure electric wires with fuses.
  • 1 ft (foot) = 0.3048 m
Wire Gauge Design Procedure
  1. calculate total length of wire from source to device and back again
  2. determine amount of current in wire
  3. determine correct wire gauge in the intersection of amps and feet
Note! Wire size based on 3% (0.36 V) voltage drop in a 12 Volt circuit. Always oversize wires if voltage drop is critical.
print 12V Cable Length Diagram
Example - 12 V Cable and Maximum Length and Current
The maximum current in a 12 Vgauge #6 (13.3 mm2) cable with length 15 m is approximately 15 amps according the diagram above.
The maximum current in a gauge #10(5.26 mm2cable with length 15 m is approximately 5 amps.
Electrical
12 Volt - Maximum Wire Length vs. Current
Maximum length of copper wire with 2% voltage drop.
AWG - American Wire Gauge vs. Circular Mils
AWG vs. diameter mil, circular mil, diameter in mm and area in mm2.
AWG - Wire Gauge Sizes: Current Ratings, Charts, Measurements, and Conversion Guide
Amp ratings vs. US AWG wire gauge.
AWG Wire Gauge Chart & Table – American Wire Gauge (AWG) Standards
The AWG (American Wire Gauge) wire size chart with detailed specifications on wire diameter, resistance, and ampacity. Find conversions between AWG sizes and metric units for electrical and engineering applications.
BWG - Birmingham Wire Gauge
Used to determine wall thickness of pipe - in gauge and decimal parts of inch.
Electric Cable Size vs. Current Rating
Amps vs. cable size for fixed installations in buildings.
Electric Wire - Resistance
Electric resistance in wire made of Copper, Aluminum, Brass, Constantan, Nichrome, Platinum, Silver or Tungsten.
Electrical Motors - Maximum Cable Size and Length vs. Power
Maximum electrical motor cable length vs. power.
Lead-Acid Batteries
Specific gravity and charge of lead acid batteries - temperature and efficiency.
SWG - Standard Wire Gauge
Imperial Standard Wire Gauge used with wire and sheet metal.
Wire Size Guide: Square mm to Diameter Conversion Chart
Convert wire area from square mm to diameter mm.
