Properties of some alternative fuels:
For full table with SI units and LHV values - rotate the screen!
Fuel | Cet.No1) | RON2) | MON2) | Density (lb/gal(US liq)) | Density (kg/m3) | LHV3) (Btu/gal) | LHV3) (Btu/lb) | LHV3) (kJ/kg) | LHV3) (kcal/kg) |
100% Ethanol | 8 | 109 | 90 | 6.6 | 791 | 75600 | 11500 | 26750 | 6390 |
E85, 85% Ethanol | 105 | 89 | 6.5 | 779 | 83600 | 12855 | 30000 | 7170 | |
10% Ethanol/gasoline | 96.5 | 86 | 6.1 | 731 | 111000 | 18000 | 42350 | 10110 | |
10% Ethanol/diesel | 45 | 7.0 | 839 | 123000 | 17500 | 40950 | 9780 | ||
100% Methanol | 5 | 109 | 89 | 6.7 | 803 | 56200 | 8400 | 19550 | 4670 |
100% Soy methyl-ester | 49 | 7.3 | 875 | 120200 | 16500 | 38400 | 9170 | ||
B100, 100% Biodiesel | 54 | 117000 | 15800 | 36750 | 8780 | ||||
B20, 20% Biodiesel, 80% petrodiesel | 46 | 18100 | 42100 | 10050 | |||||
#2 Diesel | 44 | 6.7-7.4 | 803-887 | 126000-130000 | 18000-19000 | 41900-44200 | 10000-10550 | ||
#1 Diesel | 44 | 7.6 | 911 | 125800 | 16600 | 38600 | 9220 | ||
Gasoline | 90-100 | 80-90 | 6 | 719 | 115400 | 19200 | 44650 | 10670 | |
CNG - Compressed Natural Gas | < 0 | > 127 | 122 | 20400 | 47450 | 11330 | |||
LNG - Liquified Natural Gas | < 0 | > 127 | 122 | 3.5 | 419 | 78000 | 22300 | 51850 | 12390 |
LPG - Propane | 109 | 96 | 4.2 | 503 | 83600 | 19900 | 46300 | 11050 | |
DME - Dimethyl ether | 55-60 | 5.6 | 671 | 74800 | 13600 | 31650 | 7550 |
1) Cetane number is a measurement of the combustion quality or ignition delay of diesel fuel during compression ignition
2) Octane number is a measure of the resistance of fuels to detonation or ignition. Research Octane Number (RON) is measured with an engine speed of 600 rpm, while Motor Octane Number (MON) is measured with an engine speed of 900 rpm.
3) LHV - Lower Heat Value - is the net amount of heat produced by combustion of a unit quantity of a fuel
• Combustion
• Thermodynamics
Combustion Heat
Combustion of Fuels - Carbon Dioxide Emission
Environmental emission of carbon dioxide CO2 when combustion fuels like coal, oil, natural gas, LPG and bio energy.
Crude Oil Properties - Standard test methods (ASTM and others)
An overview of common test methods and typical ranges of variation of petroleum quality parameters. What, why and how do the different test?
Flash Points - Liquids
The flash points for some common liquids and fuels.
Fossil vs. Alternative Fuels - Energy Content
Net (low) and gross (high) energy content in fossil and alternative fuels.
Fuels - Combustion Air and Flue Gases
Combustion air and flue gas for common fuels - coke, oil, wood, natural gas and more.
Fuels - Properties Database
Online petroleum-based fuels properties database.
Gasoline - Density, Specific Heat, Viscosity and Thermal Conductivity vs. Temperature
High and Low Heat Values
The gross (high) and net (low) heating values.
Higher Calorific Values of Common Fuels: Reference & Data
Higher and lower calorific values (heating values) for fuels like coke, oil, wood, hydrogen and others.
Hydrocarbons - Physical Data
Octane Liquid - Thermal Properties
Density, specific heat, thermal conductivity and more.
Optimal Combustion Processes - Fuel vs. Excess Air
Stable and efficient combustion requires correct mixture of fuels and oxygen.
Petroleum Products - Standard Test Methods (ASTM and others) and Specifications
An overview of common test methods and specifications of petroleum fuels. What, why and how do the different test?
