Compressed Air - Size of Pipe vs. Capacity
Recommended air pipe line sizes with schedule 40 steel pipes and air pressure 100 psi (6.9 bar, 689500 Pa):
Compressed Air - Recommended Size of Pipe vs. Capacity
Free Air Flow
(cfm)
Recommended Pipe Size (inches)
Length of Pipe (feet)
255075100150200250
5 1/2 1/2 1/2 1/2 1/2 1/2 1/2
10 1/2 1/2 1/2 1/2 1/2 1/2 1/2
15 1/2 1/2 1/2 1/2 3/4 3/4 3/4
20 1/2 1/2 3/4 3/4 3/4 3/4 3/4
25 1/2 3/4 3/4 3/4 3/4 1 1
30 1/2 3/4 3/4 3/4 1 1 1
35 3/4 3/4 3/4 3/4 1 1 1
40 3/4 3/4 3/4 1 1 1 1
45 3/4 3/4 1 1 1 1 1 1/4
50 3/4 1 1 1 1 1 1/4 1 1/4
55 3/4 1 1 1 1 1/4 1 1/4 1 1/4
60 3/4 1 1 1 1 1/4 1 1/4 1 1/4
65 3/4 1 1 1 1 1/4 1 1/4 1 1/4
70 3/4 1 1 1 1/4 1 1/4 1 1/4 1 1/4
75 1 1 1 1 1/4 1 1/4 1 1/4 1 1/4
80 1 1 1 1/4 1 1/4 1 1/4 1 1/4 1 1/4
85 1 1 1 1/4 1 1/4 1 1/4 1 1/4 1 1/4
90 1 1 1 1/4 1 1/4 1 1/4 1 1/4 1 1/2
95 1 1 1/4 1 1/4 1 1/4 1 1/4 1 1/4 1 1/2
100 1 1 1/4 1 1/4 1 1/4 1 1/4 1 1/2 1 1/2
Gases and Compressed Air
Compressed Air - Friction Loss in Hoses
Friction loss in air hoses vs. operating pressure.
Compressed Air - Pipe Line Pressure Loss - Online Calculator with Metric and Imperial Units
Calculate pressure drop in compressed air pipe lines - metric and imperial units.
Pressure loss in compressed air pipe lines.
Compressed Air Pipe Line Capacity
Capacities of compressed air pipelines - pressure ranging 5 - 250 psi (0.5 - 17 bar).
Compressed Air Pipe Lines - Pressure Loss vs. Capacity and Operating Pressure
Pressure drop in compressed air pipe lines.
Compressed Air Pipes - Fittings and Pressure Loss
Fittings in compressed air pipe lines and equivalent length pressure drop.
Compressed Air Piping - Pressure Loss Diagrams, Imperial Units
Pressure drop in compressed air pipelines with applied pressure 50, 100 and 150 psi.
Pneumatic Piping - Pressure Loss vs. Air Flow
Pressure loss in pneumatic tubes - sizes ranging 5 - 36 mm.
