Friction loss in standard air ducts:
- 1 m/s = 196.85 ft/min
- 1 m3/s = 3600 m3/h = 1000 dm3(liter)/s = 35.32 ft3/s = 2118.9 ft3/min = 13200 Imp.gal (UK)/min = 15852 gal (US)/min
- 1 mm H2O = 9.81 Pa = 9.807×10-6 N/mm2 = 0.0987×10-3 bar = 1 kp/m2 = 0.09678×10-3 atm = 1.422×10-3 psi (lbf/in2)
Example - Air Duct and Friction Loss
As indicated in the diagram above, the friction loss in a 500 mm main duct with air flow 1 m3/s - in a comfort system with air velocity limited to 5 m/s - can be estimated to 0.55 Pa/m (0.055 mm H2O/m).
• Ventilation Systems
Air Duct Friction Loss: Pressure Drop Calculator & Chart
Head loss or major loss in air ducts - equations and online calculator for rectangular and circular ducts - Imperial and SI units.
Air Duct Velocities
Typical air duct velocities in applications like ventilation systems or compressed air systems.
A major friction loss diagram for air ducts - in imperial units ranging 10 000 - 400 000 cfm.
Air Ducts - Major Friction Loss vs. Temperature and Pressure
The influence of temperature and air pressure on major friction loss.
Air Ducts - Minor Loss Coefficient Diagrams
Minor loss coefficient diagrams for air ductwork, bends, expansions, inlets and outletsĀ - SI units.
Air Ducts - Sizing
Required duct area vs. air flow.
Circular Ducts - Dimensions
Standard size of circular ventilation air ducts.
The equal friction method for sizing air ducts is easy and straightforward to use.
Duct Velocity
Calculate velocities in circular and rectangular ducts - imperial and SI-units - online calculator.
Equivalent Diameter - Rectangular vs. Circular HVAC Ducts
Rectangular equivalent diameter for air flows between 100 - 50000 cfm.
Equivalent Length vs. Minor Pressure Head Loss in Pipe and Duct Components
Minor pressure and head loss in pipes vs. equivalent length in tubes and duct systems.
Rectangular Air Ducts - Velocity Diagram
Velocity diagram for rectangular air ducts - metric units.
