Copper Tubes - Uninsulated Heat Losses
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Heat loss at various temperature differences between pipe and ambient air for 1/2" to 4" copper tubes - or pipes - are indicated below:
Uninsulated copper tube - heat loss diagram
Note that it is temperature difference that is used - and that 1 oC of temperature difference equals to 1.8 oF temperature difference.
Nominal boreHeat loss for the fluid inside pipe
(W/m)
(Btu/hr ft)
Temperature difference (oC)Temperature difference (oF)
(mm)(inches)223855406899
15 1/2 21 32 45 22 34 47
22 3/4 28 43 60 29 45 64
28 1 34 53 76 36 56 79
35 1 1/4 41 64 89 43 67 93
42 1 1/2 47 74 104 49 77 108
54 2 59 93 131 62 97 136
67 2 1/2 71 111 156 74 116 162
76 3 83 129 181 87 135 189
108 4 107 165 232 111 172 241
Example - Heat Loss from a 2" Pipe
A 2" pipe with temperature 75 oC (167 oF) is located in a room with temperature 20 oC (68 oF). The temperature difference between the pipe and the ambient room is 55 oC (99 oF).
The heat loss from the pipe to the room can be estimated from the table (or chart) above to 131 W/m.
