Pipes and Cylinders - Conductive Heat Loss
Conductive heat losses through cylinder or pipe walls.
Cylinder or pipe - heat loss
Uninsulated Cylinder or Pipe
Conductive heat loss through the wall of a cylinder or pipe can be expressed as
Q = 2 π L (ti - to) / (ln(r/ ri) / k)                              (1)
Q = heat transfer from cylinder or pipe (W, Btu/hr)
k = thermal conductivity of piping material (W/mK or W/moC, Btu/(hr oF ft2/ft))
L = length of cylinder or pipe (m, ft)
π = pi = 3.14...
to = temperature outside pipe or cylinder (K or oC, oF)
ti = temperature inside pipe or cylinder (K or oC, oF)
ln = the natural logarithm
ro = cylinder or pipe outside radius (m, ft)
ri = cylinder or pipe inside radius (m, ft)
heat loss through pipe or cylinder wall
Insulated Cylinder or Pipe
Conductive heat loss through an insulated cylinder or pipe can be expressed as
Q = 2 π L (ti - to) / ((ln(r/ ri) / k) + (ln(rs / ro) / ks))                          (2)
rs = outside radius of insulation (m, ft)
ks = thermal conductivity of insulation material (W/mK or W/moC, Btu/(hr oF ft2/ft))
Equation 2 with inside convective heat resistance can be expressed as
Q = 2 π L (ti - to) / (1 / (hc ri) + (ln(r/ ri) / k) + (ln(rs / ro) / ks))                          (3)
hc = convective heat transfer coefficient (W/m2K)
