Thermal conductivity is a material property that describes ability to conduct heat. Thermal conductivity can be defined as
The SI unit used for thermal conductivity is (W/m K), while a common Imperial unit is (Btu/h ft °F).
The thermal conductivity of ethylene depends on temperature and pressure as shown in the figures and table below.
Ethylene phase diagram
Online Ethylene Thermal Conductivity Calculator
The calculator below can be used to estimate the thermal conductivity of ethylene at given temperature and atmospheric pressure.
The output thermal conductivity is given as mW/(m K), Btu(IT)/(h ft °F), (Btu(IT) in)/(h ft2°F) and kcal(IT)/(h m K).
See also other properties of ethylene at varying temperature and pressure : Density and Specific Weight, Dynamic and kinematic viscosity and Specific heat (heat capacity),  and Thermophysical properties at standard conditions,
as well as thermal conductivity o f air, ammonia, butane, carbon dioxide, ethane, hydrogen, methane, nitrogen, propane and water . For thermal conductivity of construction materials, see related documents at the bottom of the page.
Thermal conductivity of ethylene as function of temperature, given as °C and °F, at atmospheric pressure:
Ethylene thermal conductivity 1 bara C
Ethylene thermal conductivity 1 bara F
Thermal conductivity of ethylene as function of temperature, given as °C and °F, and pressure:
Ethylene thermal conductivity pressure C
Ethylene thermal conductivity pressure F
Thermal conductivity of ethylene at gas-liquid equilibrium pressure and varying temperature, given as °C and °F:
Ethylene thermal conductivity equilibrium C
Ethylene thermal conductivity equilibrium F
Thermal conductivity of ethylene at given temperatures and pressure, SI and Imperial units:
State Temperature Pressure Thermal conductivity
(K) (°C) (°F) (bara) (psia) (mW/m K) (kcal(IT)/(h m K)) (Btu(IT)/(h ft °F)) ((Btu(IT) in)/(h ft2°F))
Liquid at
equilibrium
103.99 -169.16 -272.49 1.22E-03 0.0177 270.7 0.2328 0.1564 1.877
105 -168 -271 1.46E-03 0.0211 269.3 0.2316 0.1556 1.867
115 -158 -253 6.97E-03 0.101 255.6 0.2198 0.1477 1.772
125 -148 -235 0.0253 0.366 242.1 0.2082 0.1399 1.679
135 -138 -217 0.0739 1.07 228.8 0.1967 0.1322 1.586
145 -128 -199 0.183 2.66 216.0 0.1857 0.1248 1.498
155 -118 -181 0.398 5.77 203.5 0.1750 0.1176 1.411
165 -108 -163 0.777 11.3 191.5 0.1647 0.1106 1.328
175 -98.2 -145 1.39 20.2 180.1 0.1549 0.1041 1.249
185 -88.2 -127 2.33 33.9 169.2 0.1455 0.09776 1.173
195 -78.2 -109 3.69 53.5 158.8 0.1365 0.09175 1.101
205 -68.2 -90.7 5.56 80.7 148.8 0.1279 0.08598 1.032
215 -58.2 -72.7 8.05 117 139.2 0.1197 0.08043 0.9651
225 -48.2 -54.7 11.3 164 129.8 0.1116 0.07500 0.9000
235 -38.2 -36.7 15.3 223 120.6 0.1037 0.06968 0.8362
245 -28.2 -18.7 20.4 296 111.5 0.09587 0.06442 0.7731
255 -18.2 -0.7 26.5 384 102.1 0.08779 0.05899 0.7079
265 -8.1 17.3 33.9 492 92.17 0.07925 0.05325 0.6391
275 1.9 35.3 42.8 620 81.58 0.07015 0.04714 0.5656
Gas at
equilibrium
103.99 -169.16 -272.49 1.22E-03 0.0177 6.801 5.85E-03 3.93E-03 0.04715
105 -168 -271 1.46E-03 0.0211 6.739 5.79E-03 3.89E-03 0.04672
115 -158 -253 6.97E-03 0.101 6.622 5.69E-03 3.83E-03 0.04591
125 -148 -235 0.0253 0.366 7.012 6.03E-03 4.05E-03 0.04862
135 -138 -217 0.0739 1.07 7.585 6.52E-03 4.38E-03 0.05259
145 -128 -199 0.183 2.66 8.201 7.05E-03 4.74E-03 0.05686
155 -118 -181 0.398 5.77 8.813 7.58E-03 5.09E-03 0.06110
165 -108 -163 0.777 11.3 9.417 8.10E-03 5.44E-03 0.06529
175 -98.2 -145 1.39 20.2 10.04 8.63E-03 5.80E-03 0.06961
185 -88.2 -127 2.33 33.9 10.70 9.20E-03 6.18E-03 0.07419
195 -78.2 -109 3.69 53.5 11.45 9.85E-03 6.62E-03 0.07939
205 -68.2 -90.7 5.56 80.7 12.31 0.01058 7.11E-03 0.08535
215 -58.2 -72.7 8.05 117 13.35 0.01148 7.71E-03 0.09256
225 -48.2 -54.7 11.3 164 14.61 0.01256 8.44E-03 0.1013
235 -38.2 -36.7 15.3 223 16.19 0.01392 9.35E-03 0.1123
245 -28.2 -18.7 20.4 296 18.25 0.01569 0.01054 0.1265
255 -18.2 -0.7 26.5 384 21.17 0.01820 0.01223 0.1468
265 -8.1 17.3 33.9 492 26.05 0.02240 0.01505 0.1806
275 1.9 35.3 42.8 620 39.17 0.03368 0.02263 0.2716
Liquid 150 -123 -190 1 14.5 209.7 0.1803 0.1212 1.454
169.16 -103.99 -155.18 1 14.5 186.7 0.1605 0.1079 1.294
Gas 169.16 -103.99 -155.18 1 14.5 9.671 8.32E-03 5.59E-03 0.06705
225 -48.2 -54.7 1 14.5 12.90 0.01109 7.45E-03 0.08944
300 26.9 80.3 1 14.5 20.56 0.01768 0.01188 0.1426
375 102 215 1 14.5 31.00 0.02666 0.01791 0.2149
450 177 350 1 14.5 42.20 0.03629 0.02438 0.2926
Liquid 150 -123 -190 10 145 210.7 0.1812 0.1217 1.461
221.33 -51.82 -61.28 10 145 133.2 0.1145 0.07696 0.9235
Gas 221.33 -51.82 -61.28 10 145 14.11 0.01213 0.00815 0.09783
225 -48.2 -54.7 10 145 14.32 0.01231 0.00827 0.09929
300 26.9 80.3 10 145 21.36 0.01837 0.01234 0.1481
375 102 215 10 145 31.53 0.02711 0.01822 0.2186
450 177 350 10 145 42.58 0.03661 0.02460 0.2952
Liquid
150 -123 -190 50 725 214.7 0.1846 0.1241 1.489
225 -48.2 -54.7 50 725 135.1 0.1162 0.07806 0.9367
281.98 8.83 47.89 50 725 145.7 0.1253 0.08418 1.010
Gas
281.98 8.83 47.89 50 725 182.6 0.1570 0.10550 1.266
300 26.9 80.3 50 725 30.86 0.02653 0.01783 0.2140
375 102 215 50 725 35.45 0.03048 0.02048 0.2458
450 177 350 50 725 45.11 0.03879 0.02606 0.3128
Liquid 150 -123 -190 100 1450 219.6 0.1888 0.1269 1.523
225 -48.2 -55 100 1450 140.9 0.1212 0.08141 0.9769
Supercritical
phase
300 27 80 100 1450 79.64 0.06848 0.04602 0.5522
375 102 215 100 1450 45.20 0.03887 0.02612 0.3134
450 177 350 100 1450 50.08 0.04306 0.02894 0.3472
