Tabulated values of ethylene viscosity and viscosity units conversion are given below the figures.
Online Ethylene Viscosity Calculator
The calculator below can be used to calculate ethylene dynamic or kinematic viscosity at given temperatures and atmospheric pressure.
The atmospheric boiling point of ethylene is -104 °C (-155 °F), which gives a shift in viscosity at that temperature.
The output dynamic viscosity is given as Pas, Ns/m2, cP, mPas, lbfs/ft2 and lbm/fth, while the kinematic viscosity is given as cSt, m2/s and ft2/s.
See also other properties of Ethylene at varying temperature and pressure: Density and Specific Weight, Specific heat (heat capacity) and Thermal conductivity,  and Thermophysical properties at standard conditions,
as well as dynamic and kinematic viscosity of air, ammonia, benzene, butane, carbon dioxide, ethanol, methane, methanol, nitrogen, oxygen, propane and water.
Dynamic viscosity of ethylene at varying temperature and 1, 10 and 50 bara (14.5, 145 and 725 psia):
Ethylene dynamic viscosity pressure C
Ethylene dynamic viscosity pressure F
Kinematic viscosity of ethylene at varying temperature and 1, 10 and 50 bara (14.5, 145 and 725 psia):
Ethylene kinematic viscosity pressure C
Ethylene kinematic viscosity pressure F
Ethane kinematic viscosity pressure F
Dynamic viscosity of ethylene at gas-liquid equilibrium pressure:
Ethylene dynamic viscosity equilibrium C
Ethylene dynamic viscosity equilibrium F
Kinematic viscosity of ethylene at gas-liquid equilibrium pressure:
Ethylene kinematic viscosity equilibrium C
Ethylene kinematic viscosity equilibrium F
Dynamic (absolute) and kinematic viscosity of ethylene at given temperatures and pressures, SI and Imperial units:
For full table with Imperial Units and Kinematic Viscosity - rotate the screen!
State Temperature Pressure Dynamic (Absolute) Viscosity Kinematic viscosity
(K) (°C) (°F) (bara) (psia) (μPa s) (cP),
(mPa s)
(×10-6 lbf s/ft2) (×10-6 lbm/ft s) (lbm/ft h) (cSt),
(×10-6 m2/s)
(×10-6 ft2/s)
Liquid at
equilibrium
103.99 -169.16 -272.49 1.22E-03 0.0177 685.7 0.6857 14.32 460.8 1.659 1.048 11.28
105 -168 -271 1.46E-03 0.0211 662.5 0.6625 13.84 445.2 1.603 1.014 10.92
115 -158 -253 6.97E-03 0.101 488.1 0.4881 10.19 328.0 1.181 0.7620 8.202
125 -148 -235 0.0253 0.366 378.7 0.3787 7.909 254.5 0.9161 0.6033 6.494
135 -138 -217 0.0739 1.07 305.5 0.3055 6.381 205.3 0.7390 0.4971 5.350
145 -128 -199 0.183 2.66 253.8 0.2538 5.301 170.5 0.6140 0.4221 4.543
155 -118 -181 0.398 5.77 215.7 0.2157 4.505 144.9 0.5218 0.3670 3.950
165 -108 -163 0.777 11.3 186.4 0.1864 3.893 125.3 0.4509 0.3248 3.496
175 -98.2 -145 1.39 20.2 163.0 0.1630 3.404 109.5 0.3943 0.2913 3.136
185 -88.2 -127 2.33 33.9 143.9 0.1439 3.005 96.70 0.3481 0.2642 2.844
195 -78.2 -109 3.69 53.5 127.7 0.1277 2.667 85.81 0.3089 0.2413 2.597
205 -68.2 -90.7 5.56 80.7 113.8 0.1138 2.377 76.47 0.2753 0.2218 2.388
215 -58.2 -72.7 8.05 117 101.4 0.1014 2.118 68.14 0.2453 0.2045 2.202
225 -48.2 -54.7 11.3 164 90.22 0.09022 1.884 60.63 0.2183 0.1891 2.035
235 -38.2 -36.7 15.3 223 79.89 0.07989 1.669 53.68 0.1933 0.1748 1.882
245 -28.2 -18.7 20.4 296 70.14 0.07014 1.465 47.13 0.1697 0.1614 1.738
255 -18.2 -0.7 26.5 384 60.69 0.06069 1.268 40.78 0.1468 0.1486 1.599
265 -8.1 17.3 33.9 492 51.11 0.05111 1.067 34.34 0.1236 0.1358 1.461
275 1.9 35.3 42.8 620 40.40 0.04040 0.8438 27.15 0.09773 0.1221 1.314
Gas at
equilibrium
103.99 -169.16 -272.49 1.22E-03 0.0177 0.773 7.73E-04 0.01614 0.5192 1.87E-03 195.2 2101
105 -168.2 -271 1.46E-03 0.0211 1.001 1.00E-03 0.02091 0.6726 2.42E-03 213.8 2301
115 -158.2 -252.7 6.97E-03 0.101 2.734 2.73E-03 0.05710 1.837 6.61E-03 133.5 1437
125 -148.2 -234.7 0.0253 0.366 3.826 3.83E-03 0.07991 2.571 9.26E-03 55.98 602.6
135 -138.2 -216.7 0.0739 1.07 4.558 4.56E-03 0.09520 3.063 0.01103 24.55 264.3
145 -128.2 -198.7 0.183 2.66 5.089 5.09E-03 0.1063 3.420 0.01231 11.83 127.3
155 -118.2 -180.7 0.398 5.77 5.511 5.51E-03 0.1151 3.703 0.01333 6.261 67.39
165 -108.2 -162.7 0.777 11.3 5.880 5.88E-03 0.1228 3.951 0.01422 3.599 38.74
175 -98.2 -145 1.39 20.2 6.228 6.23E-03 0.1301 4.185 0.01507 2.220 23.90
185 -88.2 -127 2.33 33.9 6.577 6.58E-03 0.1374 4.420 0.01591 1.452 15.63
195 -78.2 -109 3.69 53.5 6.941 6.94E-03 0.1450 4.664 0.01679 0.9976 10.74
205 -68.2 -90.7 5.56 80.7 7.334 7.33E-03 0.1532 4.928 0.01774 0.7136 7.681
215 -58.2 -72.7 8.05 117 7.769 7.77E-03 0.1623 5.221 0.01879 0.5278 5.681
225 -48.2 -54.7 11.3 164 8.261 8.26E-03 0.1725 5.551 0.01998 0.4013 4.319
235 -38.2 -36.7 15.3 223 8.834 8.83E-03 0.1845 5.936 0.02137 0.3120 3.359
245 -28.2 -18.7 20.4 296 9.525 9.53E-03 0.1989 6.401 0.02304 0.2470 2.659
255 -18.2 -0.7 26.5 384 10.4 0.01040 0.2172 6.988 0.02516 0.1980 2.132
265 -8.1 17.3 33.9 492 11.63 0.01163 0.2429 7.815 0.02813 0.1602 1.724
275 1.9 35.3 42.8 620 13.77 0.01377 0.2876 9.253 0.03331 0.1294 1.392
Liquid 150 -123 -190 1 14.5 233.4 0.2334 4.875 156.8 0.5646 0.3925 4.225
169.16 -103.99 -155.18 1 14.5 176.1 0.1761 3.678 118.3 0.4260 0.3055 3.289
Gas 169.16 -103.99 -155.18 1 14.5 6.026 6.03E-03 0.1259 4.049 0.01458 2.922 31.45
225 -48.2 -54.7 1 14.5 7.838 7.84E-03 0.1637 5.267 0.01896 5.157 55.51
300 26.9 80.3 1 14.5 10.38 0.01038 0.2168 6.975 0.02511 9.179 98.80
375 102 215 1 14.5 12.83 0.01283 0.2680 8.621 0.03104 14.22 153.1
450 177 350 1 14.5 15.09 0.01509 0.3152 10.14 0.03650 20.10 216.4
Liquid 150 -123 -190 10 145 233.0 0.2330 4.866 156.6 0.5636 0.3914 4.213
221.33 -51.82 -61.28 10 145 94.21 0.094 1.968 63.31 0.2279 0.1946 2.094
Gas 221.33 -51.82 -61.28 10 145 8.072 8.07E-03 0.1686 5.424 0.01953 0.4425 4.763
225 -48.2 -54.7 10 145 8.177 8.18E-03 0.1708 5.495 0.01978 0.4611 4.964
300 26.9 80.3 10 145 10.59 0.01059 0.2212 7.116 0.02562 0.8874 9.552
375 102 215 10 145 13.02 0.01302 0.2719 8.749 0.03150 1.408 15.16
450 177 350 10 145 15.28 0.01528 0.3191 10.27 0.03696 2.010 21.63
Liquid 150 -123 -190 50 725 231.2 0.2312 4.829 155.4 0.5593 0.3864 4.159
225 -48.2 -54.7 50 725 93.29 0.09329 1.948 62.69 0.2257 0.1916 2.062
281.98 8.83 47.89 50 725 27.67 0.02767 0.5779 18.59 0.06694 0.1090 1.173
Gas 281.98 8.83 47.89 50 725 19.00 0.01900 0.3968 12.77 0.04596 0.1085 1.168
300 26.9 80.3 50 725 13.34 0.01334 0.2786 8.964 0.03227 0.1520 1.636
375 102 215 50 725 14.29 0.01429 0.2985 9.602 0.03457 0.2740 2.949
450 177 350 50 725 16.28 0.01628 0.3400 10.94 0.03938 0.4058 4.368
Liquid 150 -123 -190 100 1450 229.0 0.2290 4.783 153.9 0.5540 0.3804 4.094
225 -48.2 -55 100 1450 96.61 0.09661 2.018 64.92 0.2337 0.1941 2.090
Supercritical
phase
300 27 80 100 1450 37.62 0.03762 0.7857 25.28 0.09101 0.1165 1.254
375 102 215 100 1450 17.40 0.01740 0.3634 11.69 0.04209 0.1423 1.532
450 177 350 100 1450 18.01 0.01801 0.3761 12.10 0.04357 0.2119 2.281
Unit conversion:
Viscosity Dynamic, Absolute
centipoise (cP), gram/(centimeter second) (g/(cm s)) = poise (P),  kilogram/meter second (kg/m s)=newton second/square meter (N s/m2)= pascal second (Pa s), pound/(foot hour) (lb/(ft h)), pound/(foot second) (lb/(ft s)), reyn (reyn)
  • 1 cP = 0.001 Pa s = 0.01 P = 0.01 g/(cm sec) = 6.72197×10-4 lb/(ft s) = 2.4191 lb/(ft h)
  • 1 kg/(m s) = 1 (N s)/m2= 1 Pa s = 10 P = 1000 cP = 0.672197 lb/(ft s) = 2419.09 lb/(ft h)
  • 1 (N s)/m2= 1 kg/(m s) = 1 Pa s = 10 P = 1000 cP = 0.672197 lb/(ft s) = 2419.09 lb/(ft h)
  • 1 reyn = 6894.76 Pa s
Viscosity Kinematic
centistoke (cSt) = square millimeter/second (mm2/s), square foot/hour (ft2/h), square foot/second (ft2/s), square inch/second (in2/s), square meter/hour (m2/h), square meter/second (m2/s), stoke (St) = square centimeter/second (cm2/s)
  • 1 cm2/s = 1 St = 100 mm2/s = 100 cSt = 1×10-4 m2/s = 0.36 m2/h = 1.07639×10-3 ft2/s = 3.875008 ft2/h = 0.1550003 in2/s
  • 1 cSt = 1 mm2/s = 0.01 St = 1×10-6 m2/s = 0.0036 m2/h = 1.07639×10-5ft2/s = 0.03875008 ft2/h = 0.001550003 in2/s
  • 1 ft2/h = 2.7778×10-4 ft2/s = 0.04 in2/s = 2.58064×10-5m2/s = 0.09290304 m2/h = 25.8064 cS = 0.258064 St
  • 1 m2/h = 1/3600 m2/s = 2.7778×10-4 m2/s = 2.7778 cm2/s = 277.78 mm2/s = 277.78 cSt = 2.7778 St = 0.00298998 ft2/s = 10.7639 ft2/h = 0.430556 in2/s
  • 1 m2/s = 3600 m2/h = 1×104 cm2/s = 1×104 St = 1×106 mm2/s = 1×106 cSt = 10.7639 ft2/s = 38750.08 ft2/h = 1550003 in2/s
  • 1 mm2/s = 1 cSt = 1×10-6 m2/s = 0.0036 m2/h = 0.01 cm2/s = 0.01 St = 1.07639×10-5ft2/s = 0.03875008 ft2/h = 0.001550003 in2/s
  • 1 St = 1 cm2/s = 100 cSt = 100 mm2/s = 1×10-4 m2/s = 0.36 m2/h = 1.076×10-3 ft2/s = 3.875008 ft2/h = 0.1550003 in2/s
