Tabulated values of methanol viscosity and viscosity units conversion are given below the figures.
Online Methanol Viscosity Calculator
The calculator below can be used to estimate dynamic or kinematic viscosity of liquid methanol at given temperatures. The atmospheric boiling point of methanol is 64.15 °C (147.47 °F), and methanol must be pressurized to be present as liquid above that temperature.
The output dynamic viscosity is given as Pas, Ns/m2, cP, mPas, lbfs/ft2 and lbm/fth, while the kinematic viscosity is given as cSt, m2/s and ft2/s.
See also other properties of Methanol at varying temperature and pressure: Density and specific weight and Specific Heat (Heat Capacity), and Thermophysical properties at standard conditions,
as well as dynamic and kinematic viscosity of air, ammonia, benzene, butane, carbon dioxide, ethane, ethanol, ethylene, methane, nitrogen, oxygen, propane and water.
Dynamic and kinematic viscosity of liquid methanol at varying temperature:
Methanol viscosity liquid C
Methanol viscosity liquid F
The atmospheric boiling point of methanol is 64.15 °C (147.47 °F), and methanol must therefore be pressurized to be present as liquid above that temperature.
Dynamic (absolute) and kinematic viscosity of liquid methanol at given temperatures and pressures, SI and Imperial units:
State Temperature Dynamic (Absolute) Viscosity Kinematic viscosity
(K) (°C) (°F) (μPa s) (cP),
(mPa s)
(×10-6 lbf s/ft2) (×10-6 lbm s/ft s) (lbm/ft h) (cSt),
(×10-6 m2/s)
(×10-6 ft2/s)
Liquid 248.2 -25 -13 1258 1.258 0.02627 0.8453 0.003043 1.508 16.23
273.2 0.0 32 795.0 0.7950 0.01660 0.5342 0.001923 0.9815 10.56
293.2 20 68 594.0 0.5940 0.01241 0.3991 0.001437 0.7500 8.073
298.2 25 77 543.5 0.5435 0.01135 0.3652 0.001315 0.6906 7.434
303.2 30 86 507.0 0.5070 0.01059 0.3407 0.001226 0.6488 6.983
323.2 50 122 392.0 0.3920 0.00819 0.2634 0.000948 0.5142 5.535
348.2 75* 167* 294.0 0.2940 0.00614 0.1976 0.000711 0.4000 4.306
373.2 100* 212* 227.0 0.2270 0.00474 0.1525 0.000549 0.3206 3.451
* The atmospheric boiling point of methanol is 64.15 °C (147.47 °F), and methanol must therefore be pressurized to be present as liquid above that temperature.
Unit conversion:
Viscosity Dynamic, Absolute
centipoise (cP), gram/(centimeter second) (g/(cm s)) = poise (P),  kilogram/meter second (kg/m s)=newton second/square meter (N s/m2)= pascal second (Pa s), pound/(foot hour) (lb/(ft h)), pound/(foot second) (lb/(ft s)), reyn (reyn)
  • 1 cP = 0.001 Pa s = 0.01 P = 0.01 g/(cm sec) = 6.72197×10-4 lb/(ft s) = 2.4191 lb/(ft h)
  • 1 kg/(m s) = 1 (N s)/m2= 1 Pa s = 10 P = 1000 cP = 0.672197 lb/(ft s) = 2419.09 lb/(ft h)
  • 1 (N s)/m2= 1 kg/(m s) = 1 Pa s = 10 P = 1000 cP = 0.672197 lb/(ft s) = 2419.09 lb/(ft h)
  • 1 reyn = 6894.76 Pa s
Viscosity Kinematic
centistoke (cSt) = square millimeter/second (mm2/s), square foot/hour (ft2/h), square foot/second (ft2/s), square inch/second (in2/s), square meter/hour (m2/h), square meter/second (m2/s), stoke (St) = square centimeter/second (cm2/s)
  • 1 cm2/s = 1 St = 100 mm2/s = 100 cSt = 1×10-4 m2/s = 0.36 m2/h = 1.07639×10-3 ft2/s = 3.875008 ft2/h = 0.1550003 in2/s
  • 1 cSt = 1 mm2/s = 0.01 St = 1×10-6 m2/s = 0.0036 m2/h = 1.07639×10-5ft2/s = 0.03875008 ft2/h = 0.001550003 in2/s
  • 1 ft2/h = 2.7778×10-4 ft2/s = 0.04 in2/s = 2.58064×10-5m2/s = 0.09290304 m2/h = 25.8064 cS = 0.258064 St
  • 1 m2/h = 1/3600 m2/s = 2.7778×10-4 m2/s = 2.7778 cm2/s = 277.78 mm2/s = 277.78 cSt = 2.7778 St = 0.00298998 ft2/s = 10.7639 ft2/h = 0.430556 in2/s
  • 1 m2/s = 3600 m2/h = 1×104 cm2/s = 1×104 St = 1×106 mm2/s = 1×106 cSt = 10.7639 ft2/s = 38750.08 ft2/h = 1550003 in2/s
  • 1 mm2/s = 1 cSt = 1×10-6 m2/s = 0.0036 m2/h = 0.01 cm2/s = 0.01 St = 1.07639×10-5ft2/s = 0.03875008 ft2/h = 0.001550003 in2/s
  • 1 St = 1 cm2/s = 100 cSt = 100 mm2/s = 1×10-4 m2/s = 0.36 m2/h = 1.076×10-3 ft2/s = 3.875008 ft2/h = 0.1550003 in2/s
