Tabulated values and viscosity units conversion are given below the figures.
Benzene phase diagram
Online Liquid Benzene Viscosity Calculator
The calculator below can be used to estimate liquid benzene dynamic or kinematic viscosity at given temperatures. The calculator gives the viscosity at saturation pressure. For most practicle issues this can be used for liquid benzene at any pressure up to the critical point (289°C, 49 bara or 552°F, 712 psia)
The output dynamic viscosity is given as Pas, Ns/m2, cP, mPas, lbfs/ft2 and lbm/fth, while the kinematic viscosity is given as cSt, m2/s and ft2/s.
See also other properties of Benzene at varying temperature and pressure: Density and specific weight, and Thermophysical properties at standard conditions, as well as dynamic and kinematic viscosity of air, ammonia, butane, carbon dioxide, ethane, ethanol, ethylene, methane, methanol, nitrogen, oxygen, propane and water.
Dynamic viscosity of benzene at gas-liquid equilibrium pressure:
Benzene dynamic viscosity equlibrium C
Benzene dynamic viscosity equlibrium F
Kinematic viscosity of benzene at gas-liquid equilibrium pressure:
Benzene kinematic viscosity equlibrium C
Benzene kinematic viscosity equlibrium F
Dynamic (absolute) and kinematic viscosity of benzene at given temperatures and pressures, SI and Imperial units:
For full table Dynamic and Kinematic Viscosity - rotate the screen!
State Temperature Pressure Dynamic (Absolute) Viscosity Kinematic viscosity
(K) (°C) (°F) (bara) (psia) (μPa s) (cP) (lbf s/ft2 ×10-6) (lbm/ft s ×10-6) (lbm/ft h) (cSt),
(m2/s ×10-6)
(ft2/s ×10-6)
Liquid at
equilibrium
278.70 5.55 41.99 0.0480 0.696 828.1 0.8281 17.30 556.5 2.003 0.9266 9.974
280 6.9 44.3 0.0515 0.747 810.4 0.8104 16.93 544.6 1.960 0.9082 9.775
300 26.9 80.3 0.138 2.00 596.2 0.5962 12.45 400.6 1.442 0.6841 7.364
320 46.9 116 0.321 4.65 452.5 0.4525 9.451 304.1 1.095 0.5324 5.730
340 66.9 152 0.661 9.59 352.7 0.3527 7.366 237.0 0.8532 0.4258 4.583
360 86.9 188 1.24 18.0 281.1 0.2811 5.871 188.9 0.6800 0.3488 3.755
380 107 224 2.16 31.3 228.4 0.2284 4.770 153.5 0.5525 0.2918 3.141
400 127 260 3.53 51.2 188.5 0.1885 3.937 126.7 0.4560 0.2485 2.674
450 177 350 9.72 141 122.5 0.1225 2.558 82.32 0.2963 0.1768 1.904
500 227 440 21.7 314 82.34 0.08234 1.720 55.33 0.1992 0.1349 1.452
550 277 530 42.1 611 52.37 0.05237 1.094 35.19 0.1267 0.1124 1.210
Gas at
equilibrium
278.7 5.6 42.0 0.0480 0.696 6.960 0.00696 0.1454 4.677 0.01684 42.88 461.6
280 6.9 44.3 0.051 0.747 6.994 0.006994 0.1461 4.700 0.01692 40.36 434.4
300 26.9 80.3 0.138 2.00 7.509 0.007509 0.1568 5.046 0.01816 17.22 185.3
320 46.9 116 0.321 4.65 8.031 0.008031 0.1677 5.397 0.01943 8.404 90.46
340 66.9 152 0.661 9.59 8.564 0.008564 0.1789 5.755 0.02072 4.574 49.24
360 86.9 188 1.24 18.0 9.113 0.009113 0.1903 6.124 0.02205 2.699 29.06
380 107 224 2.16 31.3 9.685 0.009685 0.2023 6.508 0.02343 1.708 18.38
400 127 260 3.53 51.2 10.3 0.0103 0.2151 6.921 0.02492 1.144 12.31
450 177 350 9.72 141 12.22 0.01222 0.2552 8.211 0.02956 0.5029 5.413
500 227 440 21.7 314 15.62 0.01562 0.3262 10.50 0.03779 0.2711 2.918
550 277 530 42.1 611 25.18 0.02518 0.5259 16.92 0.06091 0.1675 1.803
Liquid 298 25 77 1 14.5 604 0.604 12.6 406 1.46 0.691 7.44
323 50 122 1 14.5 436 0.436 9.11 293 1.05 0.515 5.54
348 75 167 1 14.5 335 0.335 7.00 225 0.810 0.409 4.40
Unit conversion:
Viscosity, Dynamic (Absolute)
centipoise (cP), gram/(centimeter second) (g/(cm s)) = poise (P),  kilogram/meter second (kg/m s)=newton second/square meter (N s/m2)= pascal second (Pa s), pound/(foot hour) (lb/(ft h)), pound/(foot second) (lb/(ft s)), reyn (reyn)
  • 1 cP = 0.001 Pa s = 0.01 P = 0.01 g/(cm sec) = 6.72197×10-4 lb/(ft s) = 2.4191 lb/(ft h)
  • 1 kg/(m s) = 1 (N s)/m2= 1 Pa s = 10 P = 1000 cP = 0.672197 lb/(ft s) = 2419.09 lb/(ft h)
  • 1 (N s)/m2= 1 kg/(m s) = 1 Pa s = 10 P = 1000 cP = 0.672197 lb/(ft s) = 2419.09 lb/(ft h)
  • 1 reyn = 6894.76 Pa s
Viscosity, Kinematic
centistoke (cSt) = square millimeter/second (mm2/s), square foot/hour (ft2/h), square foot/second (ft2/s), square inch/second (in2/s), square meter/hour (m2/h), square meter/second (m2/s), stoke (St) = square centimeter/second (cm2/s)
  • 1 cm2/s = 1 St = 100 mm2/s = 100 cSt = 1×10-4 m2/s = 0.36 m2/h = 1.07639×10-3 ft2/s = 3.875008 ft2/h = 0.1550003 in2/s
  • 1 cSt = 1 mm2/s = 0.01 St = 1×10-6 m2/s = 0.0036 m2/h = 1.07639×10-5ft2/s = 0.03875008 ft2/h = 0.001550003 in2/s
  • 1 ft2/h = 2.7778×10-4 ft2/s = 0.04 in2/s = 2.58064×10-5m2/s = 0.09290304 m2/h = 25.8064 cS = 0.258064 St
  • 1 m2/h = 1/3600 m2/s = 2.7778×10-4 m2/s = 2.7778 cm2/s = 277.78 mm2/s = 277.78 cSt = 2.7778 St = 0.00298998 ft2/s = 10.7639 ft2/h = 0.430556 in2/s
  • 1 m2/s = 3600 m2/h = 1×104 cm2/s = 1×104 St = 1×106 mm2/s = 1×106 cSt = 10.7639 ft2/s = 38750.08 ft2/h = 1550003 in2/s
  • 1 mm2/s = 1 cSt = 1×10-6 m2/s = 0.0036 m2/h = 0.01 cm2/s = 0.01 St = 1.07639×10-5ft2/s = 0.03875008 ft2/h = 0.001550003 in2/s
  • 1 St = 1 cm2/s = 100 cSt = 100 mm2/s = 1×10-4 m2/s = 0.36 m2/h = 1.076×10-3 ft2/s = 3.875008 ft2/h = 0.1550003 in2/s
