Friction loss in steel pipes for fluides with various viscosities are indicated in the diagrams below.
Note that kinematic viscosity SSU 32 (1 centiStokes) equals viscosity of water at normal room temperature. Kinematic viscosity SSU 2000 (440 centiStokes) equals SAE 140 Gear Oil.
  • 1 psi/ft = 27.7 inH2O/ft = 22.6 kPa/m
  • 1 gpm = 0.23 m3/h
Pipe Size 1/2"
Pipe - pressure loss due to friction with viscous liquids - pipe size 1/2
Pipe Size 3/4"
Pipe - pressure loss due to friction with viscous liquids - pipe size 3/4
Pipe Size 1"
  • 1 gpm = 0.23 m3/h
Pipe Size 1 1/4"
Pipe - pressure loss due to friction with viscous liquids - pipe size 1 1/4
Pipe Size 1 1/2"
Pipe - pressure loss due to friction with viscous liquids - pipe size 1 1/2
Pipe Size 2"
Pipe - pressure loss due to friction with viscous liquids - pipe size 2
Pipe Size 2 1/2"
Pipe - pressure loss due to friction with viscous liquids - pipe size 2 1/2
Pipe Size 3"
Pipe Size 4"
Pipe - pressure loss due to friction with viscous liquids - pipe size 4
  • 1 gpm = 0.23 m3/h
