Friction Loss in Steel, Copper and Plastic Pipes
Friction head loss (ft/100 ft) vs. water flow in steel, copper and PVC plastic pipes.
Due to differences in inside cross sectional areas, wet surfaces and the roughness of the surfaces - there can be significant difference in friction head loss in steel, copper and plastic PVC pipes. The difference varies with size of pipe and flow rate.
  • The difference in friction loss increase with decreased dimension and increased flow rate
The friction loss in feet of head per 100 feet of Steel pipes Schedule 40, Copper pipes Type L and thermoplastic PVC pipes Schedule 40 are compared below.
  • 1 ftH2O/100 ft = 0.44 psi/100ft = 9.8 kPa/100 m = 1000 mmH2O/100 m
Friction Loss in Steel, Copper and Plastic Pipes - 3"
Flow Rate
(gal/min)
Friction Loss (ft/100 ft)
Steel pipe Schedule 40Copper pipe Type LPVC pipe Schedule 40
50 0.7 0.8 0.6
60 1.0 1.1 0.9
70 1.3 1.5 1.2
80 1.7 1.8 1.5
90 2.1 2.3 1.8
100 2.5 2.7 2.2
150 5.3 5.7 4.8
200 9.1 9.5 8.1
250 13.6 14.2 12.8
300 19.8 19.8 17.1
400 34.2 33.4 29.0
Friction Loss in Steel, Copper and Plastic Pipes - 4"
Flow Rate
(gal/min)
Steel Pipe
Schedule 40
Copper Pipe
Type L
PVC Pipe
Schedule 40
100 0.7 0.7 0.6
150 1.4 1.5 1.3
200 2.4 2.5 2.2
250 3.6 3.7 3.3
300 5.0 5.1 4.6
400 8.7 8.6 7.8
Friction Loss in Steel, Copper and Plastic Pipes - 5"
Flow Rate
(gal/min)
Steel Pipe
Schedule 40
Copper Pipe
Type L
PVC Pipe
Schedule 40
150 0.5 0.8 0.4
200 0.8 0.8 0.7
250 1.2 1.3 1.1
300 1.6 1.8 1.5
400 2.8 2.9 2.6
500 4.3 4.4 3.9
Friction Loss in Steel, Copper and Plastic Pipes - 6"
Flow Rate
(gal/min)
Steel Pipe
Schedule 40
Copper Pipe
Type L
PVC Pipe
Schedule 40
150 0.2 0.2 0.2
200 0.3 0.4 0.3
250 0.5 0.5 0.4
300 0.7 0.7 0.6
400 1.1 1.2 1.1
500 1.7 1.8 1.6
750 3.7 3.8 3.4
1000 6.3 6.5 5.8
Friction Loss in Steel, Copper and Plastic Pipes - 8"
Flow Rate
(gal/min)
Steel Pipe
Schedule 40
PVC Pipe
Schedule 40
150 0.05 0.05
200 0.08 0.08
250 0.12 0.12
300 0.17 0.16
400 0.3 0.28
500 0.4 0.4
750 0.9 0.9
1000 1.6 1.5
1250 2.4 2.3
1500 3.5 3.2
2000 6.0 5.5
Friction Loss in Steel, Copper and Plastic Pipes - 10"
Flow Rate
(gal/min)
Steel Pipe
Schedule 40
PVC Pipe
Schedule 40
200 0.03 0.03
250 0.04 0.04
300 0.06 0.05
400 0.1 0.09
500 0.15 0.14
750 0.3 0.3
1000 0.5 0.5
1250 0.8 0.8
1500 1.1 1.1
2000 1.9 1.8
Friction Loss in Steel, Copper and Plastic Pipes - 12"
Flow Rate
(gal/min)
Steel Pipe
Schedule 40
PVC Pipe
Schedule 40
400 0.04 0.04
500 0.06 0.06
750 0.13 0.13
1000 0.2 0.21
1250 0.3 0.32
1500 0.5 0.45
2000 0.8 0.8
3000 1.7 1.6
