Lined Pipes - Pressure Loss vs. Water Flow
Pressure drop diagrams for PTFE, PP, PFA and PVDF lined pipes.
The diagrams below indicates the pressure loss for water flow in PTFE-lined steel pipes schedule 40.
The pressure drop calculations are made with the D'Arcy-Weisbach Equation.
Pressure Drop - Imperial Units
Lined steel pipes - pressure drop diagram - imperial units - psi
  • 1 gal (US)/min =6.30888×10-5 m3/s = 0.227 m3/h = 0.06309 dm3(litre)/s = 2.228×10-3 ft3/s = 0.1337 ft3/min
  • 1 ft/s = 0.3048 m/s
  • 1 psi (lb/in2) = 6,894.8 Pa (N/m2) = 6.895×10-3 N/mm2 = 6.895×10-2 bar = 27.71 in H2O at 61 oF (16.7 oC) = 703.1 mm H2O at 61 oF (16.7 oC) = 2.0416 in mercury at 61 oF (16.7 oC) = 51.8 mm mercury at 61 oF (16.7 oC) = 703.6 kg/m2 = 2.307 Ft. H2O
Pressure Drop - SI units
Lined steel pipes - pressure drop diagram - imperial units - pa
  • 1 Pa = 10-6 N/mm2 = 10-5 bar = 0.1020 kp/m2 = 1.02×10-4 m H2O = 9.869×10-6 atm = 1.45×10-4 psi (lbf/in2)
  • 1 liter/s = 10-3 m3/s = 3.6 m3/h = 0.03532 ft3/s = 2.1189 ft3/min (cfm) = 13.200 Imp.gal (UK)/min = 15.852 gal (US)/min = 792 Imp. gal (UK)/h
The diagram above is based on the inside thickness of schedule 40 steel pipes with PTFE as the lining material. Common thickness of other lining materials:
Lined Pipes - Lining Materials
Lining MaterialCommon Thickness of Lining Material (inches)
Pipe Diameter (inches)
11 1/223468
PTFE*) 0.130 0.150 0.160 0.160 0.160 0.275 0.310
PP 0.135 0.160 0.175 0.175 0.210 0.220 0.220
PFA 0.113 0.114 0.114 0.130 0.150 0.145 0.140
PVDF 0.125 0.125 0.125 0.125 0.145 0.160 0.185
  • PTFE - PolyTetraFluoroEthylene
  • PP - PolyPropylene
  • PFA - Perfluoroalkoxy Fluorocarbon
  • PVDF - Polyvinylidene Fluoride
*) used in the diagrams above
