Stainless Steel Weld Fittings - ANSI/ASME B36.19
Dimensions of stainless steel weld fittings according ANSI/ASME B36.19.
Dimensions of stainless steel weld fittings according ANSI/ASME 36.19M Stainless Steel Pipe are indicated in the tables below.
Note! Wall thicknesses and weights are different for different stainless steel schedules.
Stainless Steel Elbows and Returns
For full table with 180o Returns - rotate the screen!
Stainless Steel Weld Fittings - ANSI/ASME B36.19 - Dimensions Stainless Steel Elbows and Returns
Nominal
Pipe
Size
(inches)
Outside
Diameter
90o Elbows45o Elbows180o Returns
Long RadiusShort RadiusLong RadiusLong Radius
(mm)(inches)Center to Face
(inches)
Center to Face
(inches)
Center to Face
(inches)
Radius
(inches)
Center to Center
(inches)
Back to face
(inches)
1/2 21.3 0.840 1 1/2 - 5/8   2 1 7/8
3/4 26.7 1.050 1 1/8 - 7/16   2 1/4 1 11/16
1 33.4 1.315 1 1/2 1 7/8   3 2 3/16
1 1/4 42.2 1.660 1 7/8 1 1/4 1   3 3/4 2 3/4
1 1/2 48.3 1.900 2 1/4 1 1/2 1 1/8 3 4 1/2 3 1/4
2 60.3 2.375 3 2 1 3/8 4 6 4 3/16
2 1/2 73.0 2.875 3 3/4 2 1/2 1 3/4 5 7 1/2 5 3/16
3 88.9 3.500 4 1/2 3 2 6 9 6 1/4
3 1/2 101.6 4.000 5 1/4 3 1/2 2 1/4 7 10 1/2 7 1/4
4 114.3 4.500 6 4 2 1/2 8 12 8 1/4
5 141.3 5.563 7 1/2 5 3 1/8 10 15 10 5/16
6 168.3 6.625 9 6 3 3/4 12 18 12 5/16
8 219.1 8.625 12 8 5 12 24 16 5/16
10 273.1 10.750 15 10 6 1/4 15 30 20 3/8
12 323.9 12.750 18 12 7 1/2 18 36 24 3/8
Stainless Steel Tees, Caps, Stub Ends and Straight Crosses
For full table with Stub Ends - rotate the screen!
Stainless Steel Weld Fittings - ANSI/ASME B36.19 - Dimensions Stainless Steel Tees, Caps, Stub Ends and Straight Crosses
Nominal
Pipe
Size
(inches)
Outside
Diameter
CapsStraight TeesStraight CrossesStub Ends
(mm)(inches)Length
(inches)
Center to End
(inches)
Center to End
(inches)
Lap Diameter
(inches)
Long Length
(inches)
Short Length
(inches)
1/2 21.3 0.840 1 1 - 1 3/8 3 2
3/4 26.7 1.050 1 1 1/8 - 1 11/16 3 2
1 33.4 1.315 1 1/2 1 1/2 1 1/2 2 4 2
1 1/4 42.2 1.660 1 1/2 1 7/8 1 7/8 2 1/2 4 2
1 1/2 48.3 1.900 1 1/2 2 1/4 2 1/4 2 7/8 4 2
2 60.3 2.375 1 1/2 2 1/2 2 1/2 3 5/8 6 2 1/2
2 1/2 73.0 2.875 1 1/2 3 3 4 1/8 6 2 1/2
3 88.9 3.500 2 3 3/8 3 3/8 5 6 2 1/2
3 1/2 101.6 4.000 2 1/2 3 3/4 3 3/4 5 1/2 6 3
4 114.3 4.500 2 1/2 4 1/8 4 1/8 6 3/16 6 3
5 141.3 5.563 3 4 7/8 4 7/8 7 5/16 8 3
6 168.3 6.625 3 1/2 5 5/8 5 5/8 8 1/2 8 3 1/2
8 219.1 8.625 4 7 7 10 5/8 8 4
10 273.1 10.750 5 8 1/2 8 1/2 12 3/4 10 5
12 323.9 12.750 6 10 10 15 10 6
Stainless Steel Reducers
Stainless Steel Weld Fittings - ANSI/ASME B36.19 - Dimensions Stainless Steel Reducers
Nominal
Pipe
Size
Outside
Diameter
Reducers
Reduced from
(inches)
(mm)(inches)Reduced to
(inches)
Concentric & Eccentric Length
(inches)
1/2 21.3 0.840 1/4 1 1/2
3/8 1 1/2
3/4 26.7 1.050 3/8 2
1/2 2
1 33.4 1.315 3/8 2
1/2 2
3/4 2
1 1/4 42.2 1.660 1/2 2
3/4 2
1 2
1 1/2 48.3 1.900 1/2 2 1/2
3/4 2 1/2
1 2 1/2
1 1/4 2 1/2
2 60.3 2.375 3/4 3
1 3
1 1/4 3
1 1/2 3
2 1/2 73.0 2.875 1 3 1/2
1 1/4 3 1/2
1 1/2 3 1/2
2 3 1/2
3 88.9 3.500 1 3 1/2
1 1/2 3 1/2
2 3 1/2
2 1/2 3 1/2
3 1/2 101.6 4.000 1 1/4 4
1 1/2 4
2 4
2 1/2 4
3 4
4 114.3 4.500 1 1/2 4
2 4
2 1/2 4
3 4
3 1/2 4
5 141.3 5.563 2 5
2 1/2 5
3 5
3 1/2 5
4 5
6 168.3 6.625 2 1/2 5 1/2
3 5 1/2
3 1/2 5 1/2
4 5 1/2
5 5 1/2
8 219.1 8.625 3 6
3 1/2 6
4 6
5 6
6 6
10 273.1 10.750 4 7
5 7
6 7
8 7
12 323.9 12.750 5 8
6 8
8 8
10 8
