Section Modulus - Unit Converter
Convert between Elastic Section Modulus units.
The Elastic Section Modulus of a beam is the ratio of the cross section Area Moment of Inertia to its greatest distance from the neutral axis.
Area moment of inertia - Square section
For a simple solid Square the Section Modulus can be expressed as
Sx = Sy
= a3/ 6                                         (1)
S = Elastic Section Modulus - related to bending around x vs. y axis (m3, cm3, ft3, in3)
a = square side distance (m, in, ft..)
Converter
Convert fromMultiply with
Convert to
m3cm3ft3in3
m3 1 106 35.31466 61,023.76
cm3 10-6 1 3.5×10-5 6.1×10-2
ft3 0.02831685 28373 1 1728
in3 0.00001638706 16.38 5.78×10-4 1
Example - Convert Section Modulus in unit in3 to cm3
12 in3 can be converted to cm3 by multiplying with 16.38 - as
(12 in3) (16.38 cm3/in3) = 196.6 cm3
