Area Moment of Inertia Converter
Convert between Area Moment of Inertia units.
Area Moment of Inertia or Moment of Inertia of an Area - also known as Second Moment of Area - I, is a property of shape that is used to predict deflection, bending and stress in beams.
Area moment of inertia - Square section
The general equation for Moment of Inertia for bending around an axis can be expressed as
Iaxis = ∫ y2 dA                          (1)
Iaxis = Area Moment of Inertia related to an axis (m4, mm4, in4, ft4)
y = the perpendicular distance from axis to the element dA (m, mm, in, ft)
dA = an elemental area (m2, mm2, in2, ft2)
Convert from
Multiply with
Convert to
m4cm4mm4in4ft4
m4 1 108 1012 2.4×106 116.3
cm4 10-8 1 104 2.4×10-2 1.2×10-6
mm4 10-12 10-4 1 2.4×10-6 1.2×10-10
in4 4.16×10-7 41.6 4.16×105 1 4.8225×10-5
ft4 8.6×10-3 8.6×105 8.6×109 207346 1
Example - Convert between Area of Inertia Units
To convert from 160.6 cm4 to in4 multiply with 2.4×10-2 as
(160.6 cm4) 2.4×10-2 = 3.9 in4
Moment of Inertia - Unit Converter Chart
Moment of Inertia - Unit Converting chart
Download and print Moment of Inertia - Unit Converting Chart
Moment of Inertia - Unit Converting Chart Example
100 cm4 (1.00×102 cm4) can be converted to 10000000 mm4 (1.00×107 mm4) or 24 in4 (2.4×101 in4) as indicated in the chart below:
Moment opf Inertia Converter Chart Example
