The ideal gas law treats the molecules of a gas as point particles with perfectly elastic collisions. This works well for dilute gases in many experimental circumstances.
However,  gas molecules are not point masses, and there are many cases gases need to be treated as non-ideal .  Johannes D. van der Waals suggested a modification to take into account molecular size and molecular interaction forces. It is usually referred to as the van der Waals equation of state:
(P + a (n / V)2) (V / n - b) = R T                       (1)
The constants a and b are called van der Waals constants. They have positive values and are characteristic of the individual gas. If a gas behaves ideally, both a and b are zero, and van der Waals equations approaches the ideal gas law P V = n R T.
The constant a provides a correction for the intermolecular forces.
Constant b adjusts for the volume occupied by the gas particles. It is a correction for finite molecular size and its value is the volume of one mole of the atoms or molecules.
See also the Gas Compressibility Factor, z-factor for air, dependent on pressure and temperature and used to account for deviation from the ideal situation.
How to calculate total pressure and partial pressures from Ideal gas law
* To convert a into atm L2/mol2multiply by 0.986 atm/bar. To convert a into kPa L2/mol2multiply by 100.0 kPa/bar.
Non-ideal gas - Van der Waal's Constants
Name Molecular Formula a*
bar L2/mol2
b
L/mol
Aluminum trichloride AlCl3 42.63 0.245
Ammonia NH3 4.225 0.03713
Ammonium chloride NH4 Cl 2.38 0.00734
Argon Ar 1.355 0.03201
Boron trichloride BCl3 15.6 0.1222
Boron trifluoride BF3 3.98 0.05443
Diborane B2H6 6.048 0.07437
Bromine Br2 9.75 0.0591
Perchloryl fluoride ClFO2 7.371 0.0713
Chlorine pentafluoride ClF5 9.58 0.08204
Phosphonium chloride ClH4 P 4.111 0.04545
Chlorine Cl2 6.343 0.05422
Trichlorofluorosilane Cl3 FSi 15.67 0.1273
Fluorine F2 1.171 0.02896
Germanium tetrachloride GeCl4 23.12 0.1489
Nitrogen trifluoride F3 N 3.58 0.05453
Phosphorus trifluoride F3 P 4.954 0.0651
Tetrafluorohydrazine F4 N2 7.426 0.08564
Germane GeH4 5.743 0.06555
Helium He 0.0346 0.0238
Hydrogen bromide HBr 4.5 0.04415
Hydrogen chloride HCl 3.7 0.04061
Hydrogen cyanide HCN 11.29 0.08806
Hydrogen fluoride HF 9.565 0.0739
Hydrogen iodide HI 6.309 0.05303
Hydrogen H2 0.2453 0.02651
Water H2O 5.537 0.03049
Hydrogen sulphide H2S 4.544 0.04339
Hydrogen selenide H2Se 5.523 0.0479
Krypton Kr 2.325 0.0396
Silane SiH4 4.38 0.0579
Silicon tetrachloride SiCl4 20.96 0.147
Silicon tetrafluoride SiF4 5.259 0.07236
Titanium(IV) chloride TiCl4 25.47 0.1423
Mercury Hg 5.193 0.01057
Nitric oxide NO 1.46 0.0289
Nitrogen dioxide NO2 5.36 0.0443
Nitrogen N2 1.37 0.0387
Nitrous oxide N2O 3.852 0.04435
Hydrazine N2H4 8.46 0.0462
Neon Ne 0.208 0.01672
Oxygen O2 1.382 0.03186
Ozone O3 3.57 0.0487
Phosphorus P 53.6 0.157
Phosphine PH3 4.696 0.05157
Radon Rn 6.601 0.06239
Stannic chloride SnCl4 27.25 0.1641
Sulphur S 24.3 0.066
Sulphur dioxide SO2 6.865 0.05679
Sulphur hexafluoride SF6 7.857 0.08786
Selenium Se 33.4 0.0675
Uranium(VI) fluoride UF6 16.01 0.1128
Tungsten(VI) fluoride WF6 13.25 0.1063
Xenon Xe 4.192 0.05156
Xenon difluoride XeF2 12.46 0.07037
Xenon tetrafluoride XeF4 15.52 0.09035
Chlorotrifluoromethane CClF3 6.873 0.0811
Trichlorofluoromethane CCl3 F 14.68 0.1111
Tetrachloromethane CCl4 20.01 0.1281
Tetrafluoromethane CF4 4.04 0.06325
Carbon monoxide CO 1.472 0.03948
Carbon oxysulphide COS 6.975 0.06628
Carbon dioxide CO2 3.658 0.04286
Carbon disulphide CS2 11.25 0.07262
Trichloromethane CHCl3 15.34 0.1019
Trifluoromethane CHF3 5.378 0.06403
Dichloromethane CH2Cl2 12.44 0.08689
Difluoromethane CH2F2 6.184 0.06268
Chloromethane CH3 Cl 7.566 0.06477
Fluoromethane CH3F 5.009 0.05617
Nitromethane NH3 NO2 17.18 0.1041
Methane CH4 2.3 0.04301
Methanol CH3 OH 9.472 0.06584
Methanethiol CH3 SH 8.911 0.06756
Methylamine CH3 NH2 7.106 0.05879
1,1,2-Trichlorotrifluoroethane C2Cl2F3 20.25 0.1481
Tetrafluoroethylene C2F4 6.954 0.08085
Cyanogen C2N2 7.803 0.6952
Acetylene C2H2 4.516 0.0522
1,1-Difluoroethylene C2H2F2 6 0.07058
1,1,1-Trichloroethane C2H3 Cl3 20.15 0.1317
Fluroethylene C2H3 F 5.984 0.06504
1,1,1-Trifluoroethane C2H3 F3 9.302 0.09572
Acetonitrile C2H3 N 17.89 0.1169
Ethylene C2H4 4.612 0.05821
1,1-Dichloroethane C2H4 Cl2 15.73 0.1072
1,2-Dichloroethane C2H4 Cl2 17 0.108
Ethylene oxide C2H4 O 8.922 0.06779
Acetic acid CH3 COOH 17.71 0.1065
Methyl formate C2H4 O2 11.54 0.08442
Bromoethane C2H5 Br 11.89 0.08406
Chloroethane C2H5 Cl 11.7 0.09
Fluoroethane C2H5 F 8.17 0.07758
Ethane C2H6 5.57 0.06499
Dimethyl ether C2H6 O 8.69 0.07742
Ethanol C2H5 OH 12.56 0.0871
Dimethyl sulphide C2H5 SH 13.34 0.09453
Ethanethiol C2H5 SH 13.23 0.09447
Dimethylamine C2H7 N 10.44 0.0851
Ethylamine C2H7 N 10.79 0.08433
Perfluoropropane C3 F8 12.96 0.1338
Propanenitrile C3 H5 N 21.57 0.1369
Propene C3 H6 8.438 0.08242
Cyclopropane C3 H6 8.293 0.0742
Acetone C3 H6 O 16.02 0.1124
Propanal C3 H6 O 14.08 0.09947
Ethyl formate C3 H6 O2 15.91 0.1115
Methyl acetate C3 H6 O2 15.75 0.1108
Propanoic acid C3 H6 O2 23.49 0.1386
1-Chloropropane C3 H7 Cl 16.11 0.1141`
Propane C3 H8 9.385 0.09044
1-Propanol C3 H8 O 16.26 0.108
2-Propanol C3 H8 O 15.82 0.1109
Ethyl methyl ether C3 H8 O 12.7 0.1034
Ethyl methyl sulphide C3 H8 S 19.45 0.13
Propylamine C3 H9 N 15.26 0.1094
Trimethylamine C3 H9 N 13.37 0.1101
Furan C4 H4 O 12.74 0.0926
Thiophene C4 H4 S 17.21 0.1058
Pyrrole C4 H4 N 18.82 0.1049
1,3-Butadiene C4 H6 12.17 0.102
Acetic anhydride C4 H6 O3 26.8 0.157
Butanenitrile C4 H7 N 25.76 0.1568
1-Butene C4 H8 12.76 0.1084
Cyclobutane C4 H8 12.39 0.096
2-Butanone C4 H8 O 19.97 0.1326
Tetrahydrofuran C4 H8 O 16.39 0.1082
1,4-Dioxane C4 H8 O2 19.29 0.1171
Ethyl acetate C4 H8 O2 20.57 0.1401
Methyl propanoate C4 H8 O2 20.51 0.1377
Propyl formate C4 H8 O2 20.79 0.1377
Butanoic acid C4 H8 O2 28.18 0.1609
Pyrrolidine C4 H9 N 16.84 0.1056
Butane C4 H10 13.93 0.1168
Isobutane C4 H10 13.36 0.1168
1-Butanol C4 H10 O 20.9 0.1323
2-Methyl-2-propanol C4 H10 O 18.81 0.1324
2-Methyl-1-propanol C4 H10 O 20.35 0.1324
Diethyl ether C4 H10 O 17.46 0.1333
Diethyl sulphide C4 H10 S 22.85 0.1462
Butylamine C4 H11 N 19.41 0.1301
Diethylamine C4 H11 N 19.4 0.1383
Tetramethylsilane C4 H12 Si 20.81 0.1653
Furfural C5 H4 O2 22.23 0.1182
Pyridine C5 H5 N 19.77 0.1137
Cyclopentene C5 H8 15.61 0.1097
1-Pentene C5 H10 17.86 0.137
2-Methyl-1-butene C5 H10 16.9 0.129
2-Methyl-2-butene C5 H10 17.26 0.1279
Cyclopentane C5 H10 16.94 0.118
Tetrahydropyran C5 H10 O 20.02 0.1247
Isobutyl formate C5 H10 O2 22.82 0.1476
Propyl acetate C5 H10 O2 26.23 0.17
Ethyl propanoate C5 H10 O2 25.86 0.1688
Methyl butanoate C5 H10 O2 25.83 0.1661
Methyl isobutanoate C5 H10 O2 24.87 0.1639
Piperidine C5 H11 N 20.84 0.125
Pentane C5 H12 19.13 0.1451
Isopentane C5 H12 18.29 0.1415
Neopentane C5 H12 17.17 0.141
1-Pentanol C5 H12 O 25.81 0.1564
Bromobenzene C6 H5 Br 28.96 0.1541
Chlorobenzene C6 H5 Cl 25.8 0.1454
Fluorobenzene C6 H5 F 20.1 0.1279
Iodobenzene C6 H5 I 33.54 0.1658
Benzene C6 H6 18.82 0.1193
Phenol C6 H5 OH 22.93 0.1177
Aniline C6 H5 NH2 29.14 0.1486
Cyclohexanone C6 H10 O 31.1 0.17
Hexanenitrile C6 H11 N 35.5 0.1996
Cyclohexane C6 H12 21.95 0.1413
Cyclohexanol C6 H11 OH 28.93 0.1586
Pentyl formate C6 H12 O2 27.97 0.173
Isobutyl acetate C6 H12 O2 29.05 0.1845
Ethyl butanoate C6 H12 O2 30.53 0.1922
Ethyl 2-methylpropanoate C6 H12 O2 29.05 0.1872
Methyl pentanoate C6 H12 O2 29.39 0.1847
Hexane C6 H14 24.97 0.1753
2,3-Dimethylbutane C6 H14 23.29 0.166
1-Hexanol C6 H14 O 31.35 0.1829
Triethylamine C6 H15 N 27.59 0.1836
Dipropylamine C6 H15 N 24.82 0.1591
Benzonitrile C7 H5 N 33.89 0.1727
Benzaldehyde C7 H6 O 30.3 0.1553
Toluene C7 H8 24.89 0.1499
o-Cresol C7 H8 O 28.33 0.1447
m-Cresol C7 H8 O 31.86 0.1609
p-Cresol C7 H8 O 28.11 0.1422
Benzyl alcohol C7 H8 O 34.7 0.173
Anisole C7 H8 O 28.6 0.1579
Heptane C7 H16 30.89 0.2038
Heptanol C7 H15 OH 37.22 0.2097
Ethylbenzene C8 H10 30.86 0.1782
o-Xylene C8 H10 31.06 0.1756
m-Xylene C8 H10 31.41 0.1814
p-Xylene C8 H10 31.54 0.1824
Phenetole C8 H10 O 35.7 0.1966
N,N-Dimethylaniline C8 H11 N 37.92 0.1967
Octane C8 H18 37.86 0.2372
2,5-Dimethylhexane C8 H18 35.49 0.2299
1-Octanol C8 H18 O 43.42 0.2371
Quinoline C9 H7 N 36.7 0.1672
Cumene C9 H12 36.2 0.2044
Propylbenzene C9 H12 37.14 0.2073
1,2,4-Trimethylbenzene C9 H12 38.03 0.2088
Mesitylene C9 H12 37.87 0.2118
Nonane C9 H20 45.11 0.2702
1-Nonanol C9 H20 O 50 0.2654
Naphthalene C10 H8 40.32 0.192
Butylbenzene C10 H14 44.07 0.2378
Isobutylbenzene C10 H14 40.4 0.2215
o-Cymene C10 H14 42.7 0.234
p-Cymene C10 H14 45.27 0.2478
p-Diethylbenzene C10 H14 45.03 0.2439
1,2,4,5-Tetramethylbenzene C10 H14 45.8 0.24
Decane C10 H22 52.88 0.3051
1-Decanol C10 H22 O 57.45 0.2971
Undecane C11 H24 60.88 0.3396
Biphenyl C12 H10 47.16 0.213
Dodecane C12 H26 69.14 0.3741
1-Dodecanol C12 H26 O 72.69 0.3598
Diphenylmethane C13 H12 60.46 0.2798
Tridecane C13 H28 77.94 0.4109
1-Tridecanol C13 H28 O 81.2 0.3942
1-Tetradecanol C14 H30 O 89.91 0.4289
Pentadecane C15 H32 96.5 0.4857
* To convert a into atm L2/mol2 multiply by 0.986 atm/bar
* To convert a into kPa L2/mol2 multiply by 100.0 kPa/bar
