Helium - Thermophysical Properties
Chemical, Physical and Thermal Properties of Helium - He.
Chemical, physical and thermal properties of Helium - He :
(values at 25 oC (77 oF, 298 K) and atmospheric pressure)
Molecular Weight 4.0026
Specific Gravity, air = 1 0.138
Specific Volume (ft3/lb, m3/kg) 97.86, 6.11
Density of liquid at atmospheric pressure (lb/ft3, kg/m3) 7.80, 125
Absolute Viscosity (lbm/ft s, centipoises) 13.4×10-6, 0.02
Sound velocity in gas (m/s) 1015
Specific Heat - cp - (Btu/lb oF or cal/g oC, J/kgK) 1.24, 5188
Specific Heat Ratio - cp/cv 1.66
Gas constant - R - (ft lb/lb oR, J/kg oC) 386, 2077
Thermal Conductivity (Btu/hr ft oF, W/moC) 0.086, 0.149
Boiling Point - saturation pressure 14.7 psia and 760 mm Hg - (oF,o K) -452, 4.22
Latent Heat of Evaporation at boiling point (Btu/lb, J/kg) 10.0, 23300
Critical Temperature (oF,o K) -450.3, 5.2
Critical Pressure (psia, MN/m2) 33.22, -
Critical Volume (ft3/lb, m3/kg) 0.231, 0.0144
Flammable no
Follow the links below to get values for the listed properties of helium at varying pressure and temperature :
as well as Thermophysical properties of: Acetone, Acetylene, Air, Ammonia, Argon, Benzene, Butane, Carbon dioxide, Carbon monoxide, Ethane, Ethanol, Ethylene, Hydrogen, Hydrogen sulfide, Methane, Methanol, Nitrogen, Oxygen, Pentane, Propane, Toluene, Water and Heavy water, D2O .
