The term partial pressure is used when we have a mixture of two or several gases in the same volume, and it expresses the pressure that is caused by each of the induvidual gases in the mixture.
The total pressure of the gas mixture is the sum of the partial pressure of the component gases:
Ptot = ∑P i = P1 + P2+ P3 ...
Where
Ptot = the total pressure
Pi = the pressure of  component i ( i can vary from 1,2,3.....up to the number of different gases in the mixture)
From the Ideal Gas Law we have:
PV = n R T  or    P = n R T / V
Then,
Ptot = ntot R T / V      and Pi = ni R T / V
ni = the number of moles of component i
ntot = the total number of moles in the gas mixture, which is the sum of all ni .
R = the gas constant = 8.3145 (J/mol K) = 0.08206 (L atm/mol K)  = 62.37 (L torr /mol K)
T = absolute temperature (K)
V = volume (m3) or (L)
For a gas mixture, the temperature and the volume is the same for all gases, and the gas constant is always the same, and then we get:
Pi / Ptot =  (ni R T / V) / (ntot R T / V)  = ni / ntot
We can express the concentration of one gas in the gas mixture as the mole fraction, Xi :
Xi = ni / ntot
and then
Pi / Ptot = Xi or  Pi = Xi Ptot
See also Non-ideal gas - Van der Waal's equation and constants
Example 1.
Dry air consists mainly of nitrogen (78.09 vol% or 75.47 wt%),oxygen (20.95 vol% or 23.20 wt%), argon (0.93 vol% or 1.28 wt%) and carbondioxide (0.03 vol% or 0.046 wt%).
If you have 100 g of dry air in a 50 liter closed container, what will the partial pressure of each gas be, and what will the total pressure be at 120°C?
First, we must find how many moles of each gas, using the weight fraction of each gas and molweight of the gases :
nN2 = 100(g) * 0.7547 /28.02 (g/mol) = 2.693 mol N2
nO2 = 100(g) * 0.2320 /32.00 (g/mol) = 0.725 mol O2
nAr = 100(g) * 0.0128 /39.95 (g/mol) = 0.032 mol Ar
nCO2 = 100(g) * 0.00046 /44.01 (g/mol) = 0.001 mol CO2
ntot = nN2 + nO2 + nAr + nCO2 = 3.451 mol gas
Then, assuming the gas mixture behaves ideally, we have:
The total pressure, Ptot = ntot R T / V = 3.451 (mol)* 0.08206 (L atm/mol K)* (273+120) (K) / 50 (L) = 2.226 atm
PN2 = XN2 * Ptot = nN2 /ntot * Ptot = (2.693(mol)/3.451(mol))*2.226 atm = 1.737 atm
PO2 = XO2 * Ptot = nO2 /ntot * Ptot = (0.725(mol)/3.451(mol))*2.226 atm = 0.468 atm
PAr = XAr * Ptot = nAr /ntot * Ptot = (0.032(mol)/3.451(mol))*2.226 atm = 0.021 atm
PCO2 = XCO2 * Ptot = nCO2 /ntot * Ptot =(0.001(mol)/3.451(mol))*2.226 atm = 0.0006 atm
