Industrial Lubricants - Viscosities vs. ISO-VG Grade
ISO-VG viscosity grades for industrial lubricants.
The diagram below indicates the minimum and maximum viscosities in centistokes for equivalent ISO-VG grades at temperature 40 oC.
Lubricants - Iso-vg grade viscosity diagram
ISO VG stands for "International Standards Organization Viscosity Grade" and is a number ranged from 2 to 1500.
Equivalent Viscosities of ISO-VG Grades at 40 oC and SAE Crankcase Oil Grades
ISO-VG GradeSAE Crankcase Oil Grade
22 5W
32 10W
46 15W
68 20W
100 30
150 40
220 50
320 60
Equivalent Viscosities of ISO-VG Grades at 40 oC and SAE Aircraft Oil Grades
ISO-VG GradeSAE Aircraft Oil Grade
100 65
150 80
220 100
320 120
Equivalent Viscosity of ISO-VG Grades at 40 oC and SAE Gear Lube Grades
ISO-VG GradeSAE Gear Lube Grade
46 75W
100 80W-90
220 90
460 85W-140
1500 250
Equivalent Viscosity of ISO-VG Grades at 40 oC and AGMA Gear Lube Grades
ISO-VG GradeAGMA Gear Lube Grade
RegularEP
46 1
68 2 2 EP
100 3 3 EP
150 4 4 EP
220 5 5 EP
320 6 6 EP
460 7 7 EP
680 8 8 EP
ISO-VG Grades - Absolute Viscosity vs. Temperature, Reyns vs. Fahrenheit
Lubricants - Iso-vg temperature absolute viscosity diagram
ISO-VG Grades - Absolute Viscosity vs. Temperature, centiPoise vs. Celsius
Lubricants - Iso-vg temperature absolute viscosity diagram - centiPoise vs. Temperature
  • tC = 5/9 (tF - 32)
  • tF = 9/5 tC + 32
  • 1 reyns (lb s/in2) = 6896.55 (Pa s)
  • 1 cSt (centiStoke) = 1 centiPoise / SG
  • SG = specific gravity of oil
