API Gravity: Definition, Calculation, and Converter
API expresses the gravity or density of liquid petroleum products. Online API to Specific Gravity calculator.
API gravity express the gravity or density of crude oil and liquid petroleum products. API is devised jointly by the American Petroleum Institute and the NIST - National Institute of Standards and Technology . The measuring scale is calibrated in terms of degrees API.
API Gravity can be calculated as:
°API = (141.5 / SG) - 131.5                                               (1)
°API = Degrees API Gravity
SG = Specific Gravity (at 60 oF)
Specific gravity can be calculated from API gravity:
SG = 141.5 / (°API + 131.5)                                               (2)
Note! Oil with the least specific gravity has the highest API gravity
SG - API Converter
Density is a temperature depedent property. API gravity increases with increasing temperature, while specific gravity decreases with increasing temperature. See correlations at Density of crude oil as function of temperature . This means that the volume of a petroleum liquid increases with increasing temperature, and that a density number always must be given with the measurement temperature. The standard measuring temperature is 15°C or 60°F.
See also Standard test methods (ASTM and others) for crude oil properties, and temperature correlations for lubricating oil, fuel oils and jet fuel.
Density Crude Oil vs. Degree API
Degree APISpecific Gravity Weight
(lb/US gal)(kg/m3)
1 1.068 8.894 1067
5 1.037 8.633 1035
8 1.014 8.447 1013
10 1.000 8.328 998.9
15 0.9659 8.044 964.8
20 0.9340 7.778 933.1
25 0.9042 7.530 903.2
30 0.8762 7.297 875.3
35 0.8498 7.078 848.9
40 0.8251 6.871 824.3
45 0.8017 6.677 800.8
50 0.7796 6.493 778.8
55 0.7587 6.319 757.9
60 0.7389 6.154 738.1
70 0.7022 5.848 701.5
80 0.6690 5.572 668.3
90 0.6388 5.320 638.1
API_gravity
  • There is no clear definition of the different classes of crude oil; extra heavy oil (bitumen), heavy oil, medium oil, light oil, condensate. Different sources and different countries use their own limits. The boxes in the figure indicate the most common ranges used.
