Aluminum I-Beams
Dimensions and static properties of aluminum I-beams - Imperial units.
Properties in imperial units of aluminum I-beams are indicated below.
For full table with Static Parameters Moment of Inertia and Elastic Section Modulus - rotate the screen!
Designation | Dimensions | Static Parameters | |||||||
Moment of Inertia | Elastic Section Modulus | ||||||||
Imperial (in x in) | Depth - h - (in) | With - w - (in) | Web Thickness - s - (in) | Sectional Area (in2) | Weight (lbf/ft) | - Ix - (in4) | - Iy - (in4) | - Sx - (in3) | - Sy - (in3) |
3 x 2 1/2 | 3 | 2.5 | 0.13 | 1.39 | 1.64 | 2.24 | 0.52 | 1.49 | 0.42 |
3 x 2 1/2 | 3 | 2.5 | 0.15 | 1.73 | 2.03 | 2.71 | 0.68 | 1.81 | 0.54 |
4 x 3 | 4 | 3 | 0.15 | 1.97 | 2.31 | 5.62 | 1.04 | 2.81 | 0.69 |
4 x 3 | 4 | 3 | 0.17 | 2.38 | 2.79 | 6.71 | 1.31 | 3.36 | 0.87 |
5 x 3 1/2 | 5 | 3.5 | 0.19 | 3.15 | 3.70 | 13.9 | 2.29 | 5.58 | 1.31 |
6 x 4 | 6 | 4 | 0.19 | 3.43 | 4.03 | 22.0 | 3.10 | 7.33 | 1.55 |
6 x 4 | 6 | 4 | 0.21 | 3.99 | 4.69 | 25.5 | 3.74 | 8.50 | 1.87 |
7 x 4 1/2 | 7 | 4.5 | 0.23 | 4.93 | 5.80 | 42.9 | 5.78 | 12.3 | 2.57 |
8 x 5 | 8 | 5 | 0.23 | 5.26 | 6.18 | 59.7 | 7.30 | 14.9 | 2.92 |
8 x 5 | 8 | 5 | 0.25 | 5.97 | 7.02 | 67.8 | 8.55 | 16.9 | 3.42 |
9 x 5 1/2 | 9 | 5.5 | 0.27 | 7.11 | 8.36 | 102 | 12.2 | 22.7 | 4.44 |
10 x 6 | 10 | 6 | 0.25 | 7.35 | 8.65 | 132 | 14.8 | 26.42 | 4.93 |
10 x 6 | 10 | 6 | 0.29 | 8.75 | 10.29 | 156 | 18.0 | 31.2 | 6.01 |
12 x 7 | 12 | 7 | 0.29 | 9.93 | 11.67 | 256 | 26.9 | 42.6 | 7.69 |
12 x 7 | 12 | 7 | 0.31 | 12.2 | 14.29 | 317 | 35.5 | 52.9 | 10.1 |
- 1 in = 25.4 mm
- 1 cm4 = 10-8 m = 104 mm
- 1 in4 = 4.16×105 mm4 = 41.6 cm4
- 1 cm3 = 10-6 m = 103 mm
I-shaped cross-section beams:
- Britain : Universal Beams (UB) and Universal Columns (UC)
- Europe : IPE. HE. HL. HD and other sections
- US : Wide Flange (WF) and H sections
