Refractive Index common Liquids, Solids and Gases
Some common liquids, solids, and gases and their refractive indexes.
Refraction is an effect that occurs between transparent materials of different densities.
The Refractive Index  - n - of a medium is a measure for how much the velocity of light is reduced inside the medium. The velocity of light in a medium can be expressed as
v  = c / n                                          (1)
v = velocity of light in the medium (m/s, ft/s)
c = speed of light in air or vacuum - approximately 3×108 m/s (or 299792458 m/s)
n = refractive index
The index of refraction is defined as
  • "the speed of light in vacuum divided by the speed of light in the medium".
Eq. 1 modified
n  = c / v                                          (2)
reflecting and refraction of light beam at the interface between two media
Index of Refraction for Vacuum
  • n = 1.00
Refractive Indices for some common Gases
Common Gases - Refractive Index
GasRefractive Index
- n -
Acetone 1.001090
Air (-15 oC) 1.00030942
Air (0 oC) 1.00029238
Air (15 oC) 1.00027712
Air (30 oC) 1.00026337
Air (60 oC) 1.00023958
Alcohol, ethyl 1.000878
Alcohol, methyl 1.000586
Ammonia 1.000376
Argon 1.000281
Benzene 1.001762
Bromine 1.001132
Carbon dioxide 1.000449
Carbon disulphide 1.001481
Carbon monoxide 1.000338
Chlorine 1.000773
Chloroform 1.001450
Ether, ethyl 1.001533
Ether, methyl 1.000891
Helium 1.000035
Hydrochloric acid 1.000447
Hydrogen 1.000132
Methane 1.000444
Nitric oxide 1.000297
Nitrogen 1.000298
Nitrous oxide 1.000516
Oxygen 1.000271
Pentane 1.000686
Sulphur dioxide 1.000686
Vacuum 1.000000
Water vapor 1.000261
Index of Refraction for common Liquids
Common Fluids - Refractive Index
FluidRefractive Index
- n -
Acetic Acid 1.37
Acetone 1.36
Alcohol, ethyl (ethanol) 1.36
Alcohol, methyl (methanol) 1.33
Alcohol, propyl 1.38
Aniline 1.586
Benzene 1.501
Benzyl benzoate 1.568
Carbon disulfide 1.63
Carbon tetrachloride 1.46
Chlorobenzene 1.525
Chloroform 1.44
Decane 1.41
Dodecane 1.41
Ether 1.35
Ethylene glycol 1.43
Ethyl salicylate 1.523
Ethyl cinnamate 1.559
Trichlorofluoromethane refrigerant R-11 1.37
Dichlorodifluoromethanerefrigerant R-12 1.29
Chlorodifluoromethane refrigerant R-22 1.26
Furan 1.47
Glyserine (Glycerol) 1.47
Heptane 1.38
Hexane 1.37
Hydrogen liquid 1.0974
Methyl salicylate 1.538
Methylene iodine 1.737
Milk 1.35
Octane 1.40
Oil, cedar 1.516
Oil, vegetable 50 oC 1.47
Oil, oiive 1.46
Oil, turpentine 1.47
Paraldehyde 1.405
Parafin, liquid 1.48
Propane 1.34
Propylene 1.36
Propylene glycol 1.43
Quinoline 1.627
Toluene 1.497
Turpentine (wood) 1.47
Water 0 oC 1.33346
Water 20 oC 1.33283
Water 100 oC 1.31766
Example - Speed of Light in Air
The speed of light in air can be calculated as
v  = (299792458 m/s) / 1.000293
    = 299704645 m/s
Example - Speed of Light in Water
The approximate speed of light in water can be calculated as
v  = (3×108 m/s) / 1.33
    = 2.26 108 m/s
Index of Refraction for some common Solids
Common Solids - Refractive Index
SolidRefractive Index
- n -
Crown glass 1.5 - 1.62
Diamond 2.417
Flint glass 1.57 - 1.75
Headlamp lenses glass 1.52
Ice 1.31
Plexiglas 1.49
Quartz glass 1.46
Salt 1.52
Standard glass for optics (BK 7) 1.51673
Window glass 1.52
Example - Speed of Light in Glass
The approximate speed of light in glass can be calculated as
v  = (3×108 m/s) / 1.6
    = 1.88 108 m/s
Index of Refraction for some selected Polymers
Common Polymers - Refractive Index
PolymerRefractive Index
- n -
Acrylic 1.48 - 1.50
Celulose Acetat 1.46 - 1.50
Epoxy resin 1.6
HDPE 1.5
Polycarbonate 1.59
PTFE 1.35
Polyester 1.50 - 1.58
Polymethylmethacrylate 1.49
Polystyrene 1.59
Polyvinylchloride 1.54
Vinylidene chloride 1.6 - 1.63
