Physical Constants
Physical constants - SI Units.
Physical Constants
DescriptionSymbolFormulaValue1Unit1Value2Unit2
Absolute zero, temperature 0 K -273.15 oC
Acceleration of gravity at earth's surface g 9.81 m/s2 32.2 ft/s2
Atmospheric pressure at sea level 1.01325×105 N/m2 14.69 lb/in2
Atomic mass unit 1.660540×10-27 kg 1.000 u
Avogadro's constant NA 6.022141×1023 mol-1
Base of natural logaritms e 2.718 281 828...
Base of natural logaritms lnx 2.3026 log(x)
Bohr magneton μB e h/4πme 9.274009994×10-24 Am2 5.788381×10-5 eV/T
Bohr radius a0 ε0h2/π mee2 5.2917721067×10-11 m 2.08×10-9 in
Boltzmann constant k R/NA 1.38064852×10-23 J/K 8.617330×10-5 eV/K
Charge of electron e 1.602176×10-19 C
Faraday constant F e NA 9.648533289×104 C/mol 26.801 Ah/mol
Fine structure constant α 7.29720×10-3
Gas constant (molar, ideal) R 8.3144598 J/molK 82.057338 cm3atm/molK
Gravitational constant G 6.67408×10-11 m3/kg s2
Mass of electron (rest mass) me 9.10938356×10-31 kg 5.485799×10-4 u
Mass of neutron mn 1.67492747×10-27 kg 1.008664915 u
Mass of proton mp 1.67262190×10-27 kg 1.007276466 u
Permeability of a vacuum μ0 4p×10-7 kg m/s2A2
Permittivity of a vacuum ε0 1/μ0 c02 8.854187817×10-12 C2/Nm2 A2s4/kg m3
Planck's constant h 6.626070040×10-34 J s 4.135667×10-15 eV s
Radiation constant, first C1 2 π h c2 3.741844×10-16 Wm2
Radiation constant, second C2 h c/k 1.438833×10-2 mK
Ratio of a circle's circumference(C) to its diameter π C/d 3.141592653…
Rydberg constant R∞ mee4/8ε02h3c0 1.097373156×107 m-1
Speed of light in vacuum c0 2.99792458×108 m/s
Stefan-Boltzmann constant σ 5.670367×10-8 W/m2K4 11.7×10-8 cal/cm2dayK4
Volume ideal gas, 1 atm, 0°C Vm 22413.6 cm3/mol 22.4136 liter/mol
Volume ideal gas,1 atm, 25°C Vm 24466.1 cm3/mol 1.0244651 m3/mol
