Moist Air - Degree of Saturation
Humidity ratio of moist air to humidity ratio of saturated moist air.
Degree of Saturation is the ratio of the humidity ratio of moist air - to the humidity ratio of saturated moist air at the same temperature and pressure.
The Degree of Saturation can be expressed as
μ = x / xs                                 (1)
μ = degree of saturation
x = humidity ratio of the air (kgh20 /kgdry_air)
xs = humidity ratio of the air at saturation at the same temperature and pressure (kgh20 /kgdry_air)
The degree of saturation can also be expressed as:
μ = φ (pa - pws ) / (pa - pw )                       (2)
φ = relative humidity (%)
pw = vapor pressure (mbar)
pws = saturation vapor pressure at the actual dry bulb temperature (mbar)
pa = atmospheric pressure of moist air (mbar)
