The maximum moisture content possible in air - at saturation - varies with temperature. The table below indicates maximum moisture content in a cubic metre of air at various temperatures:
TemperatureMax.
Water Content
(oC)(oF)(10-3 kg/m3)(10-3lb/ft3)
-25 -13 0.64 0.040
-20 -4 1.05 0.066
-15 5 1.58 0.099
-10 14 2.31 0.14
-5 23 3.37 0.21
0 32 4.89 0.31
5 41 6.82 0.43
10 50 9.39 0.59
15 59 12.8 0.8
20 68 17.3 1.07
30 86 30.4 1.9
40 104 51.1 3.2
50 122 83.0 5.2
60 140 130 8.1
  • 10-3 kg/m3 = g/m3
Air - moisture carrying capacity vs. temperature
Example - Moisture Carrying Capacity in Heated Air
Air is heated from 20 oC to 50 oC.
  • from the table above the maximum moisture content in air at 20 oC is 17.3 g/m3, and
  • the maximum moisture content in air with temperature 50 oC is 83 g/m3
The increased ability to carry moisture can be calculated as
100 % ((83 g/m3) - (17.3 g/m3)) / (17.3 g/m3)
= 380 %
This dramatic change is important to explain why heated air is so much more effective than cold air in drying processes.
