Air Duct Components - Minor Dynamic Loss Coefficients
Minor loss (pressure or head loss) coefficients for air duct components.
Minor or Dynamic losses in duct systems are pressure losses caused by
  • change in air direction from elbows, offsets, and takeoffs
  • restrictions or obstructions in the air stream - in/outlet fans, dampers, filters, and coils
  • air velocity changes due to changes in duct sizes
Minor or dynamic pressure loss in air duct system components can be expressed as
Δpminor_loss = ξ ρ v2 / 2                            (1)
ξ = minor loss coefficient
Δpminor_loss = minor pressure loss (Pa (N/m2), psf (lb/ft2))
ρ = density of air (1.2 kg/m3, 2.336×10-3 slugs/ft3)
v = flow velocity (m/s, ft/s)
Minor loss coefficients for different components in air duct distribution systems:
Component or FittingMinor Loss Coefficient
- ξ -
90o bend, sharp 1.3
90o bend, with vanes 0.7
90o bend, rounded
radius/diameter duct <1
0.5
90o bend, rounded
radius/diameter duct >1
0.25
45o bend, sharp 0.5
45o bend, rounded
0.2
45o bend, rounded
0.05
T, flow to branch
(applied to velocity in branch)
0.3
Flow from duct to room 1.0
Flow from room to duct 0.35
Reduction, tapered 0
Enlargement, abrupt
(due to speed before reduction)
(v1= velocity before enlargement and v2 = velocity after enlargement)
(1 - v2/ v1)2
Enlargement, tapered angle < 8o
0.15 (1 - v2/ v1)2
Enlargement, tapered angle > 8o
(1 - v2/ v1)2
Grilles, 0.7 ratio free area to total surface 3
Grilles, 0.6 ratio free area to total surface 4
Grilles, 0.5 ratio free area to total surface 6
Grilles, 0.4 ratio free area to total surface 10
Grilles, 0.3 ratio free area to total surface 20
Grilles, 0.2 ratio free area to total surface 50
Air Flow - Minor Loss chart
Download and print Air Flow - Minor Loss chart
Example - Minor Loss in a Bend
The minor loss in a 90o sharp bend with minor loss coefficient 1.3 and air velocity 10 m/s can be calculated as
Δpminor_loss = (1.3) (1.2 kg/m3) (10 m/s)2 / 2
       = 78 N/m2, Pa
