Epoxy - Chemical Resistance
Chemical resistance of Epoxy to common products like Acetic acid, Alcohol, Diesel oil and more.
Epoxy (polyepoxide) is an epoxide polymer that cures when mixed with a catalyzing agent or "hardener". Epoxy resin have an excellent electrical, thermal, and chemical resistance. It is common to increase the strength of epoxy with fibrous reinforcement or mineral fillers. The variety of combinations of epoxy resins and reinforcements provides a wide latitude in properties obtainable in molded parts.
The table below can be used as an indication of epoxy resistance to chemical compounds. Always check the chemical resistance with the epoxy manufacturer.
ProductEpoxy Resistance
Acetic Acid (20%) Excellent
Acetone Not Recommended
Acetylene Excellent
Alcohol - Ethyl Excellent (temperature < 120 oF, 50 oC)
Alcohol - Isopropyl Excellent
Alcohol - Methyl Good (temperature < 71 oF, 22 oC)
Aluminum Chloride Excellent (temperature < 71 oF, 22 oC)
Aluminum Fluoride Good (temperature < 71 oF, 22 oC)
Aluminum Hydroxide Good (temperature < 71 oF, 22 oC)
Aluminum Sulfate Excellent (temperature < 71 oF, 22 oC)
Amines Excellent (temperature < 71 oF, 22 oC)
Ammonia - Liquid Excellent (temperature < 71 oF, 22 oC)
Ammonia 10% Excellent (temperature < 71 oF, 22 oC)
Ammonium Carbonate Excellent (temperature < 71 oF, 22 oC)
Ammonium Chloride Excellent (temperature < 71 oF, 22 oC)
Ammonium Hydroxide Excellent (temperature < 71 oF, 22 oC)
Ammonium Nitrate Excellent (temperature < 71 oF, 22 oC)
Ammonium Phosphate Excellent (temperature < 71 oF, 22 oC)
Ammonium Sulfate Excellent (temperature < 71 oF, 22 oC)
Amyl acetate Excellent (temperature < 71 oF, 22 oC)
Aniline Fair (temperature < 71 oF, 22 oC)
Barium Carbonate Excellent (temperature < 71 oF, 22 oC)
Barium Chloride Excellent (temperature < 71 oF, 22 oC)
Barium Hydroxide Excellent (temperature < 71 oF, 22 oC)
Barium Sulfate Fair (temperature < 71 oF, 22 oC)
Barium Sulfide Good (temperature < 71 oF, 22 oC)
Beer Excellent (temperature < 71 oF, 22 oC)
Benzol Excellent (temperature < 71 oF, 22 oC)
Borax Excellent (temperature < 71 oF, 22 oC)
Boric acid Excellent (temperature < 71 oF, 22 oC)
Bromine Not Recommended
Butadiene gas Excellent (temperature < 71 oF, 22 oC)
Butane gas Excellent (temperature < 71 oF, 22 oC)
Butyl acetate Good (temperature < 71 oF, 22 oC)
Butaric Acid Fair (temperature < 71 oF, 22 oC)
Calcium Bisulfite Excellent (temperature < 71 oF, 22 oC)
Calcium Carbonate Excellent (temperature < 71 oF, 22 oC)
Calcium Chloride Excellent (temperature < 71 oF, 22 oC)
Calcium Hydroxide Excellent (temperature < 71 oF, 22 oC)
Calcium Hypochlorite Excellent (temperature < 71 oF, 22 oC)
Calcium Sulfate Excellent (temperature < 71 oF, 22 oC)
Carbon dioxide gas Excellent (temperature < 71 oF, 22 oC)
Carbon Tetrachloride Excellent (temperature < 71 oF, 22 oC)
Carbonic Acid Good (temperature < 71 oF, 22 oC)
Citric Acid Excellent (temperature < 71 oF, 22 oC)
Copper Chloride Excellent
Copper Nitrate Excellent (temperature < 71 oF, 22 oC)
Dichloroethane Good (temperature < 120 oF, 50 oC)
Diesel Fuel Excellent (temperature < 71 oF, 22 oC)
Ethyl acetate Fair (temperature < 71 oF, 22 oC)
Ethyl chloride Excellent (temperature < 71 oF, 22 oC)
Ethylene glycol Fair (temperature < 71 oF, 22 oC)
Fatty Acids Excellent (temperature < 71 oF, 22 oC)
Ferric Chloride Excellent (temperature < 71 oF, 22 oC)
Ferric Sulfate Excellent (temperature < 71 oF, 22 oC)
Ferrous Chloride Excellent (temperature < 71 oF, 22 oC)
Ferrous Sulfate Excellent (temperature < 71 oF, 22 oC)
Fluorine gas Note Recommended
Fluosilicic acid Fair
Formaldehyde, 40% Excellent (temperature < 71 oF, 22 oC)
Formic Acid Fair (temperature < 71 oF, 22 oC)
R-12 dichlorodifluoromethane Excellent
Gasoline Excellent
Glucose Good
Glycerine Excellent
Heptane Excellent
Hexane Good
Hydraulic Fluid Excellent
Hydrobromic Acid, 100% Not Recommended
Hydrochloric acid, 20% Good (temperature < 71 oF, 22 oC)
Hydrocyanic Acid Excellent
Hydrofluoric Acid, 75% Good (temperature < 71 oF, 22 oC)
Hydrogen Peroxide, 10% Fair (temperature < 71 oF, 22 oC)
Hydrogen Sulfide Excellent
Jet Fuel Excellent
Kerosene Excellent
Lactic Acid Good (temperature < 71 oF, 22 oC)
Lead acetate Excellent
Magnesium Carbonate Excellent
Magnesium Chloride Excellent
Magnesium Hydroxide Excellent
Magnesium Nitrate Excellent
Magnesium Sulfate Excellent
Maleic Acid Excellent
Mercury Excellent
Methyl Ethyl Ketone Fair (temperature < 71 oF, 22 oC)
Naphtha Excellent
Naphthalene Excellent
Nickel Chloride Excellent
Nickel Sulfate Excellent
Nitric Acid Not Recommended
Oil - Castor Excellent
Oleic acid Excellent
Oxalic Acid Excellent
Phenol Good
Phosphoric Acid Good
Picric Acid Excellent
Potassium Bicarbonate Excellent
Potassium Bromide Excellent
Potassium Carbonate Excellent
Potassium Chloride Excellent
Potassium Dichromate Fair
Potassium Hydroxide Excellent
Potassium Nitrate Excellent
Potassium Sulfate Excellent
Propane, liquid Excellent
Silver Nitrate Excellent
Soaps Excellent
Sodium Acetate Excellent
Sodium Bicarbonate Excellent
Sodium Bisulfate Excellent
Sodium Carbonate Fair (temperature < 71 oF, 22 oC)
Sodium Chlorate Excellent
Sodium Chloride Excellent
Sodium Cyanide Excellent
Sodium Fluoride Excellent
Sodium Hydroxide, 50% Good (temperature < 120 oF, 50 oC)
Sodium Hypochlorite, 100% Not Recommended
Sodium Nitrate Excellent
Sodium Silicate Excellent
Sodium Sulfate Excellent
Sodium Sulfite Excellent
Sodium Thiosulfate Excellent
Stannic Chloride Excellent
Stearic Acid Good
Sulfuric Acid, 75-100% Fair (temperature < 71 oF, 22 oC)
Sulfur Dioxide Excellent (temperature < 71 oF, 22 oC)
Tannic Acid Excellent
Tartaric Acid Excellent
Toluene Good (temperature < 71 oF, 22 oC)
Turpentine Good
Urine Excellent
Vinegar Excellent
Water - Distilled Excellent
Water - Fresh Excellent
Water - Sea, Salt Excellent
Xylene Excellent
Zinc Chloride Excellent
