Control Valves in Series
Control valves in series - flow coefficient
The equivalent flow coefficient Kv or Cv for two control valves installed in series can be calculated as
1 / (Kvt)2 =  1 / (Kv1)2 + 1 / (Kv2)2                                      (1)
Kvt = resulting Kv
Kv1 = Kv valve 1
Kv2 = Kv valve 2
Control Valves in Parallel
Control valves in parallel - flow coefficient
The equivalent Kv or Cv for two control valves installed in parallel can be calculated as
Kvt = Kv1 + Kv2                                            (2)
