Valves - Specific Services
ServicesMainSecondary
Gases Butterfly valves
Check valves
Diaphragm valves
Lubricated plug valves
Screw down stop valves
Pressure control valves
Pressure relief valves
Pressure reducing valves
Safety valves
Relief valves
Liquids - clear up to sludges and sewage Butterfly valves
Gate valves
Diaphragm valves
Pinch valves
Slurries and liquids with solids Butterfly valves
Pinch valves
Gate valves
Steam Butterfly valves
Gate valves
Turbine valves
Check valves
Pre superheated valves
Safety and relief valves
  • Slurry - a thin mixture of a liquid like water and finely divided substances, such as cement or clay particles
  • Sludge - a semi-solid slurry. Wastewater solids are also referred to as sludge.
