Air and Steam Mixtures
Air in the steam will lower the surface temperatures in heat exchangers - and less heat will be transferred.
Air in the steam will cause the temperatures on heat-exchangers surfaces to be lower than expected due to the saturation temperatures in the steam tables. The heat transfer will be reduced and the system efficiency will be decreased.
Air in steam can be described with the "Daltons Law of Partial Pressure".
The total pressure of a mixture of gases is made up by the sum of the partial pressures of the components in the mixture as known from Dalton's Law of Partial Pressures:
The total pressure exerted by a mixture of gases is the sum of the partial pressures of the individual gases!
The total pressure in a mixture of steam and air can be expressed as:
p = pa + ps                           (1)
pa = partial pressure of air (Pa, bar, psi)
ps = partial pressure of steam (Pa, bar, psi)
The Partial Pressure in a Mixture
The partial pressure is the pressure exerted by each component as if it was occupying the same volume of the mixture. The effective partial pressure of the steam can be expressed as:
ps_effective = vs / V p                            (2)
ps_ effective = effective steam pressure, absolute (Pa, bar, psi)
vs = volume of steam (m3, in3)
V = volume of mixture (m3, in3)
p = absolute pressure (Pa, bar, psi)
Reducing the part of steam reduces the effective steam pressure. Increasing the part of steam (until 100%) increases the effective pressure.
Example - Mix of Air and Steam
The effective pressure in a steam/air mixture made up by 3 parts steam and 1 part air, with total pressure 5 bar absolute, can be expressed as:
ps_effective = (3 parts) / (3 parts + 1 part) (5 bar abs)
    = 3.75 bar absolute
Important! Since the steam has an effective pressure of 3.75 bar instead of the pressure of 5 bar a, the mixture would have a temperature of approximately 139 oC rather than the expected saturation temperature of 152 oC. This has a major effect on the heat transfer capability of an heat exchanger.
Mixing Air and Steam - Result Temperature
Mixing Air and Steam - Resulting Temperatures
Mixture Pressure0% Air
(Pure Steam)
5% Air10% Air15% Air
(psig)(bar)(oF)(oC)(oF)(oC)(oF)(oC)(oF)(oC)
2 0.15 219 104 216 102 213 101 210 99
5 0.35 227 108 225 107 222 106 219 104
10 0.7 239 115 237 114 233 112 230 110
20 1.4 259 126 256 124 252 122 249 121
Steam and air mixture - temperature
