Lined Sheet-Metal Ducts - Sound Attenuation
Noise attenuation in rectangular straight, lined, sheet metal ducts.
Attenuation in ducts with 25 mm lining are indicated below:
Sound Attenuation of Lined Sheet-Metal Ducts
Attenuation in ducts with 50 mm lining are indicated below:
Example - Sound Attenuation in Lined Duct
The sound attenuation in 610 x 610 mm lined duct is approximately 2.5 dB/m at frequency 250 Hz. The sound attenuation in 10 m duct can be calculated as
(10 m) (2.5 dB/m) = 25 dB
