Silicone - Chemical Resistance
Chemical resistance of silicone.
SubstanceClassification
Acetamide, 150 oC resistant
Acetic acid, 20 oC resistant
Acetone, 20 oC conditionally resistant
Ammonium hydroxide (conc.), 20 oC resistant
Aniline, 100 oC resistant
Petrol, 20 oC conditionally resistant
Ball bearing fat, 150 oC resistant
Brake fluid AT, 100 oC resistant
Butanol, 117 oC conditionally resistant
Butylacetate, 20 oC conditionally resistant
Calcium hydroxide, (saturated), 20 oC resistant
Carbon tetrachloride, 20 oC conditionally resistant
Chlorbenzene, 20 oC conditionally resistant
Carbolineum, 20 oC resistant
Clophene, 150 oC resistant
Cloroform, 20 oC not resistant
Compressor oil, light, 150 oC resistant
Diphenyl, 150 oC conditionally resistant
Diesel oil, 20 oC conditionally resistant
Dinamo oil, 150 oC conditionally resistant
Hydrofluor acid 5%, 20 oC not resistant
Gear oil DTE BB, 150 oC resistant
Gear oil DTE HH, 150 oC resistant
Gear oil DTE extra heavy, 150 oC resistant
Gear oil Type SEA 90, 150 oC resistant
Glycerin, 100 oC resistant
Hexa ethoxydisiloxane, 20 oC conditionally resistant
High pressure compressor oil, 150 oC resistant
Isopropyl alcohol 82 conditionally resistant
Mineral oil, 20 oC conditionally resistant
Potassium, 20 oC%, 20 oC resistant
Potassium hydroxide 50%, 20 oC resistant
Potassium permanganate solution, 20 oC resistant
Prestone, 20 oC resistant
Salt, cooking solution 10%, 20 oC
resistant
Linseed oil, 100 oC resistant
Methanol 65 conditionally resistant
Methylen chloride, 20 oC not resistant
Mineral oil ASTM No. 1, 150 oC resistant
Mineral oil ASTM No. 3, 150 oC conditionally resistant
Mineral oil SEA 10, 150 oC resistant
Mineral oil SEA, 20 oC, 150 oC resistant
Mineral oil SEA 30, 150 oC resistant
Mono styrene, 20 oC conditionally resistant
Motor oil viscose static, 150 oC resistant
Sodium, 20 oC%, 20 oC resistant
Soda 50%, 20 oC resistant
Nitrobenzene, 20 oC resistant
Oleic acid, 150 oC not resistant
Olive oil, 150 oC resistant
Perchlor, 20 oC not resistant
Petroleum ether, 20 oC not resistant
Petroleum, 20 oC conditionally resistant
Phenol 60 resistant
Phosphoric acid 30%, 20 oC resistant
Pyridine, 20 oC conditionally resistant
Regulator oil, 150 oC not resistant
Castor oil, 150 oC resistant
Hydrochlorid acid 10%, 20 oC resistant
Nitric acid conc., 20 oC not resistant
Nitric acid 10%, 20 oC conditionally resistant
Sulfuric acid, conc., 20 oC not resistant
Sulfuric acid, 10%, 20 oC resistant
Shock absorber oil, 20 oC resistant
Turbentine oil, 20 oC conditionally resistant
Toluene, 20 oC conditionally resistant
Transformer oil, 150 oC conditionally resistant
Tri, 20 oC not resistant
Tri glycol, 20 oC resistant
Vaseline, 150 oC resistant
Water, 100 oC resistant
Hydrogen peroxide 30%, 20 oC resistant
Hydrogen superoxide 30%, 20 oC resistant
In general - be careful with silicone tubes and gaskets with oil products. Depending on the content of the products silicone may - or may not - be resistant.
