Electrical Motors - Service Factors
Service factor - SF - is a measure of periodically overload capacity at which a motor can operate without beeing damaged.
electric motor
The service factor - SF - is a measure of periodically overload capacity (Design Power) at which a motor can operate without damage. The NEMA (National Electrical Manufacturers Association) standard service factor for totally enclosed motors is 1.0.
A motor operating continuously at a service factor greater than 1 will have a reduced life expectancy compared to operating at at its rated nameplate horsepower.
NEMA Service Factor at Synchronous Speed (rpm) for drip proof motors:
Electrical Motors - Service Factors vs. Power and Speed
Motor Power
(hp)
Service Factor - SF
360018001200900
1/6, 1/4, 1/3 1.35 1.35 1.35 1.35
1/2 1.25 1.25 1.25 1.25
3/4 1.25 1.25 1.15 1.15
1 1.25 1.15 1.15 1.15
1 1/2 and up 1.115 1.15 1.15 1.15
Design Power vs. Motor Power and Service Factor can be expressed as
PD = SF P              (1)
PD = design power (hp, W)
SF =service factor
P = motor power (hp, W)
Example - Design Power vs. Service Factor
A 1 HP motor with a Service Factor - SF= 1.15 can operate at
PD = (1 hp) 1.15
    = 1.15 hp
without overheating or otherwise damaging the motor if rated voltage and frequency are supplied to the motor.
Insulation life and bearings life are reduced by the service factor load.
