R22 Refrigerant - Properties
Properties of Refrigerant R22 Dichlorodifluoromethane - saturated liquid and saturated vapor - imperial and metric units.
R22 is a single HydroChloroFluoroCarbon (HCFC) compound. It has low chlorine content and ozone depletion potential and a modest global warming potential. ODP1) = 0.05 and GWP2) = 1700
R22 can be used in small heat pump systems, but new systems can not be manufactured for use in the EU after 2003. From 2010 only recycled or saved stocks of R22 can be used. It will no longer be manufactured.
Refrigerant 22 Properties in Imperial Units
For full table with Enthalpy and Entropy Liquid and Vapor - rotate the screen!
R22 Refrigerant - Properties - Imperial Units
Temperature
(oF)
Pressure
(psia)
Liquid Density
(lb/ft3)
Vapor Volume
(ft3/lb)
Enthalpy
(Btu/lb)
Entropy
(Btu/lboF)
LiquidVaporLiquidVapor
-130.00 0.696 96.46 58.544 -23.150 89.864 -0.06198 0.28082
-120.00 1.080 95.53 38.833 -20.594 91.040 -0.05435 0.27430
-110.00 1.626 94.60 26.494 -18.038 92.218 -0.04694 0.26838
-100.00 2.384 93.66 18.540 -15.481 93.397 -0.03973 0.26298
-90.00 3.413 92.71 13.275 -12.921 94.572 -0.03271 0.25807
-80.00 4.778 91.75 9.7044 -10.355 95.741 -0.02587 0.25357
-70.00 6.555 90.79 7.2285 -7.783 96.901 -0.01919 0.24945
-60.00 8.830 89.81 5.4766 -5.201 98.049 -0.01266 0.24567
-50.00 11.696 88.83 4.2138 -2.608 99.182 -0.00627 0.24220
-45.00 13.383 88.33 3.7160 -1.306 99.742 -0.00312 0.24056
-41.44 b) 14.696 87.97 3.4048 -0.377 100.138 -0.00090 0.23944
-40.00 15.255 87.82 3.2880 0.000 100.296 0.00000 0.23899
-35.00 17.329 87.32 2.9185 1.310 100.847 0.00309 0.23748
-30.00 19.617 86.81 2.5984 2.624 101.391 0.00616 0.23602
-25.00 22.136 86.29 2.3202 3.944 101.928 0.00920 0.23462
-20.00 24.899 85.77 2.0774 5.268 102.461 0.01222 0.23327
-15.00 27.924 85.25 1.8650 6.598 102.986 0.01521 0.23197
-10.00 31.226 84.72 1.6784 7.934 103.503 0.01818 0.23071
-5.00 34.821 84.18 1.5142 9.276 104.013 0.02113 0.22949
0.00 38.726 83.64 1.3691 10.624 104.515 0.02406 0.22832
5.00 42.960 83.09 1.2406 11.979 105.009 0.02697 0.22718
10.00 47.538 82.54 1.1265 13.342 105.493 0.02987 0.22607
15.00 52.480 81.98 1.0250 14.712 105.968 0.03275 0.22500
20.00 57.803 81.41 0.9343 16.090 106.434 0.03561 0.22395
25.00 63.526 80.84 0.8532 17.476 106.891 0.03846 0.22294
30.00 69.667 80.26 0.7804 18.871 107.336 0.04129 0.22195
35.00 76.245 79.67 0.7150 20.275 107.769 0.04411 0.22098
40.00 83.280 79.07 0.6561 21.688 108.191 0.04692 0.22004
45.00 90.791 78.46 0.6029 23.111 108.600 0.04972 0.21912
50.00 98.799 77.84 0.5548 24.544 108.997 0.05251 0.21821
55.00 107.32 77.22 0.5111 25.988 109.379 0.05529 0.21732
60.00 116.38 76.58 0.4715 27.443 109.748 0.05806 0.21644
65.00 126.00 75.93 0.4355 28.909 110.103 0.06082 0.21557
70.00 136.19 75.27 0.4026 30.387 110.441 0.06358 0.21472
75.00 146.98 74.60 0.3726 31.877 110.761 0.06633 0.21387
80.00 158.40 73.92 0.3451 33.381 111.066 0.06907 0.21302
85.00 170.45 73.22 0.3199 34.898 111.350 0.07182 0.21218
90.00 183.17 72.51 0.2968 36.430 111.616 0.07456 0.21134
95.00 196.57 71.79 0.2756 37.977 111.859 0.07730 0.21050
100.00 210.69 71.05 0.2560 39.538 112.081 0.08003 0.20965
105.00 225.53 70.29 0.2379 41.119 112.278 0.08277 0.20879
110.00 241.14 69.51 0.2212 42.717 112.448 0.08552 0.20793
115.00 257.52 68.71 0.2058 44.334 112.591 0.08827 0.20705
120.00 274.71 67.89 0.1914 45.972 112.704 0.09103 0.20615
125.00 292.73 67.05 0.1781 47.633 112.783 0.09379 0.20522
130.00 311.61 66.17 0.1657 49.319 112.825 0.09657 0.20427
135.00 331.38 65.27 0.1542 51.032 112.826 0.09937 0.20329
140.00 352.07 64.33 0.1434 52.775 112.784 0.10220 0.20227
145.00 373.71 63.35 0.1332 54.553 112.692 0.10504 0.20119
150.00 396.32 62.33 0.1237 56.370 112.541 0.10793 0.20006
160.00 444.65 60.12 0.1063 60.145 112.035 0.11383 0.19757
170.00 497.35 57.59 0.0907 64.175 111.165 0.12001 0.19464
180.00 554.82 54.57 0.0763 68.597 109.753 0.12668 0.19102
190.00 617.53 50.62 0.0625 73.742 107.398 0.13432 0.18613
200.00 686.11 44.44 0.0478 80.558 102.809 0.14432 0.17805
205.06 c) 723.74 32.70 0.0306 91.052 91.052 0.15989 0.15989
Refrigerant 22 Properties in Metric Units
R22 Refrigerant - Properties - SI Units
Temperature
(oC)
Presssure
(MPa)
Liquid Density
(kg/m3)
Vapor Volume
(m3/kg)
Enthalpy
(kJ/kg)
Entropy
(kJ/kgK)
-100 0.00200 1571.7 8.2980 90.24 358.93 0.5027 2.0545
-90 0.00480 1545.1 3.6548 100.95 363.82 0.5629 1.9982
-80 0.01035 1518.3 1.7816 111.66 368.75 0.6197 1.9508
-70 0.02044 1491.1 0.94476 122.36 373.68 0.6738 1.9109
-60 0.03747 1463.6 0.53734 133.11 378.58 0.7253 1.8770
-50 0.06449 1435.5 0.32405 143.91 383.39 0.7748 1.8480
-48 0.07140 1429.8 0.29469 146.08 384.35 0.7844 1.8427
-46 0.07890 1424.1 0.26849 148.25 385.29 0.7940 1.8376
-44 0.08700 1418.4 0.24507 150.43 386.23 0.8035 1.8326
-42 0.09575 1412.6 0.22410 152.61 387.17 0.8130 1.8277
-40 b) 0.10132 1409.1 0.21256 153.93 387.72 0.8186 1.8249
-40 0.10518 1406.8 0.20526 154.80 388.09 0.8224 1.8230
-38 0.11533 1401.0 0.18832 156.99 389.01 0.8317 1.8184
-36 0.12623 1395.1 0.17306 159.19 389.93 0.8410 1.8140
-34 0.13793 1389.2 0.15927 161.40 390.84 0.8502 1.8096
-32 0.15045 1383.3 0.14680 163.61 391.74 0.8594 1.8054
-30 0.16384 1377.3 0.13551 165.82 392.63 0.8685 1.8013
-28 0.17815 1371.3 0.12525 168.04 393.52 0.8776 1.7973
-26 0.19340 1365.2 0.11593 170.27 394.39 0.8866 1.7934
-24 0.20965 1359.1 0.10744 172.51 395.26 0.8955 1.7896
-22 0.22693 1352.9 0.09970 174.75 396.12 0.9044 1.7859
-20 0.24529 1346.8 0.09262 177.00 396.67 0.9133 1.7822
-18 0.26477 1340.5 0.08615 179.26 397.81 0.9222 1.7787
-16 0.28542 1334.2 0.08023 181.53 398.64 0.9309 1.7752
-14 0.30728 1327.9 0.07479 183.81 399.46 0.9397 1.7719
-12 0.33040 1321.5 0.06979 186.09 400.27 0.9484 1.7686
-10 0.35482 1315.0 0.06520 188.38 401.07 0.9571 1.7653
-8 0.38059 1308.5 0.06096 190.69 401.85 0.9657 1.7621
-6 0.40775 1301.9 0.05706 193.00 402.63 0.9743 1.7590
-4 0.43636 1295.3 0.05345 195.32 403.39 0.9829 1.7560
-2 0.46646 1288.6 0.05012 197.66 404.14 0.9915 1.7530
0 0.49811 1281.8 0.04703 200.00 404.87 1.0000 1.7500
2 0.53134 1275.0 0.04417 202.35 405.59 1.0085 1.7471
4 0.56622 1268.1 0.04152 204.72 406.30 1.0170 1.7443
6 0.60279 1261.1 0.03906 207.10 406.99 1.0254 1.7415
8 0.64109 1254.0 0.03676 209.49 407.67 1.0338 1.7387
10 0.68119 1246.9 0.03463 211.89 408.33 1.0422 1.7360
12 0.72314 1239.7 0.03265 214.31 408.97 1.0506 1.7333
14 0.76698 1232.4 0.03079 216.74 409.60 1.0590 1.7306
16 0.81277 1225.0 0.02906 219.18 410.21 1.0673 1.7280
18 0.86056 1217.6 0.02744 221.63 410.80 1.0756 1.7254
20 0.91041 1210.0 0.02593 224.10 411.38 1.0840 1.7228
22 0.96236 1202.4 0.02451 226.59 411.93 1.0923 1.7202
24 1.0165 1194.6 0.02319 229.09 412.46 1.1006 1.7177
26 1.0728 1186.8 0.02194 231.60 412.98 1.1088 1.7151
28 1.1314 1178.8 0.02077 234.14 413.46 1.1171 1.7126
30 1.1924 1170.7 0.01968 236.69 413.93 1.1254 1.7101
32 1.2557 1162.5 0.01864 239.25 414.37 1.1336 1.7075
34 1.3215 1154.2 0.01767 241.84 414.79 1.1419 1.7050
36 1.3898 1145.7 0.01675 244.44 415.18 1.1501 1.7024
38 1.4606 1137.1 0.01589 247.06 415.54 1.1584 1.6999
40 1.5341 1128.4 0.01507 249.71 415.87 1.1667 1.6973
42 1.6103 1119.5 0.01430 252.37 416.17 1.1749 1.6947
44 1.6892 1110.4 0.01357 255.06 416.44 1.1832 1.6921
46 1.7709 1101.2 0.01288 257.77 416.68 1.1915 1.6894
48 1.8555 1091.8 0.01223 260.51 416.87 1.1998 1.6867
50 1.9431 1082.1 0.01161 263.27 417.03 1.2081 1.6840
55 2.1753 1057.1 0.01020 270.31 417.24 1.2291 1.6768
60 2.4274 1030.5 0.00895 277.56 417.14 1.2503 1.6692
65 2.7008 1001.8 0.00784 285.06 416.65 1.2718 1.6610
70 2.9967 970.4 0.00684 292.90 415.69 1.2940 1.6518
75 3.3168 935.3 0.00594 301.18 414.09 1.3169 1.6413
80 3.6627 894.8 0.00511 310.10 411.60 1.3413 1.6287
85 4.0368 845.1 0.00433 320.05 407.72 1.3680 1.6128
90 4.4416 777.5 0.00355 331.98 401.33 1.3998 1.5907
95 4.8820 665.4 0.00264 348.86 387.46 1.4442 1.5491
96.14 c) 4.9900 523.8 0.00191 366.59 366.59 1.4918 1.4918
Note! b) = boiling point and c) = critical point
R417A is the zero ODP1) replacement for R22 suitable for new equipment and as a drop-in replacement for existing systems.
1) ODP - The ODP or Ozone Depletion Potential. The potential for a single molecule of the refrigerant to destroy the Ozone Layer. All refrigerants use R11 as a datum reference where R11 has an ODP of 1.0. The less the value of the ODP - the better the refrigerant is for the ozone layer and the environment.
2) GWP - The GWP, or Global Warming Potential. A measurement (usually measured over a 100-year period) of how much effect a refrigerant will have on Global Warming in relation to Carbon Dioxide. CO2 has a GWP of 1. The lower the value of GWP - the better the refrigerant is for the environment.
R22 - Saturation pressure vs. Temperature
