Refrigerant R134a - Properties
Thermodynamic properties of refrigerant R-134a.
  • 1,1,1,2-Tetrafluoroethane, R-134a
  • Genetron 134a
  • Suva 134a
  • HFC-134a
is a haloalkane refrigerant with thermodynamic properties similar to R-12 (dichlorodifluoromethane), but with less ozone depletion potential. R-134a has the formula CH2FCF3.
R-134a Properties - Imperial Units
For full table with Specific Volume, Heat Content Enthalpy Liquid and Vapor - rotate the screen!
Refrigerant R134a - Properties - Imperial Units
Temperature
(oF)
Pressure
(psia)
Pressure
(psig)
(*inches mercury below one atmosphere)
Density Liquid
(lb./cu.ft.)
Specific Volume Vapor
(cu.ft./lb.)
Heat Content - Enthalpy Liquid
(Btu/lb.)
Heat Content - Enthalpy Vapor
(Btu/lb.)
-150 0.07107 29.776* 102.34 457.07 -32.781 80.212
-125 0.28333 29.344* 99.64 123.44 -25.383 83.716
-100 0.89915 28.090* 96.89 41.52 -17.939 87.245
-75 2.3866 25.062* 94.09 16.56 -10.472 90.760
-50 5.4966 18.730* 91.22 7.56 -2.995 94.248
-25 11.2964 6.9214* 88.28 3.83 4.503 97.721
-15 14.6686 0.0555* 87.08 2.99 7.518 99.109
-10 16.6293 1.9334 86.47 2.66 9.030 99.804
-5 18.7906 4.0947 85.86 2.37 10.546 100.499
0 21.1665 6.4706 85.25 2.12 12.067 101.195
5 23.7710 9.0751 84.63 1.90 13.593 101.891
10 26.619 11.923 84.01 1.70 15.125 102.587
25 36.773 22.078 82.11 1.25 19.763 104.677
50 60.032 45.335 78.84 0.781 27.666 108.149
75 93.080 78.384 75.39 0.507 35.851 111.553
86 111.321 96.626 73.80 0.424 39.560 113.004
100 138.28 123.58 71.70 0.340 44.393 114.782
125 198.27 183.57 67.68 0.232 53.385 117.660
150 276.12 261.42 63.13 0.159 62.989 119.879
175 375.69 360.99 57.60 0.107 73.581 120.788
200 502.54 487.85 49.44 0.065 86.528 118.155
R-134a Properites - SI Units
For full table with Enthalpy and Entropy in Liquid and Vapor - rotate the screen!
Refrigerant R134a - Properties - SI Units
Temperature
(oC)
Absolute Pressure
(bar)
Density Liquid
(kg/m3)
Density Vapor
(kg/m3)
Enthalpy Liquid
(kJ/kg)
Enthalpy Vapor
(kJ/kg)
Entropy Liquid
(kJ/(kgK))
Entropy Vapor
(kJ/(kgK))
-60 0.15935 1472.0 0.9291 24.491 261.491 0.68772 1.8014
-50 0.29477 1444.9 1.6526 36.302 267.779 0.74358 1.7809
-40 0.51225 1417.0 2.773 48.631 274.068 0.79756 1.76448
-30 0.84379 1388.2 4.4307 61.130 280.324 0.84995 1.75142
-20 1.32719 1358.4 6.7903 73.833 286.513 0.901 1.74113
-10 2.00575 1327.4 10.047 86.777 292.598 0.95095 1.73309
0 2.,92769 1295.1 14.433 1000.0 298.536 1 1.72684
10 4.14571 1261.2 20.226 113.540 304.276 1.04834 1.72196
20 5.71665 1225.5 27.773 127.437 309.756 1.09613 1.71806
30 7.70132 1187.5 37.517 141.736 314.892 1.14354 1.71473
40 10.1648 1146.7 50.055 156.491 319.575 1.19073 1.71152
50 13.1773 1102.2 66.234 171.778 323.652 1.23794 1.70792
60 16.8156 1052.9 87.346 187.715 326.896 1.28548 1.70325
70 21.1668 996.49 115.564 204.515 328.941 1.3339 1.6965
80 26.3336 928.78 155.130 222.616 329.095 1.38434 1.68585
90 32.4489 838.51 216.936 243.168 325.655 1.43978 1.66692
100 39.7254 649.71 367.064 273.641 309.037 1.5198 1.61466
1,1,1,2-Tetrafluoroethane - R-134a - is an inert gas used primarily as a high-temperature refrigerant for domestic refrigeration and automobile air conditioners.
R134a - Saturation pressure vs. temperature
