Centrifugal Pumps - Speed Torque Curve
The characteristic speed torque curves for centrifugal pumps.
The speed torque curve characterize a centrifugal pump. The theoretical characteristic is a parabola starting from the origin and proportional to the square of the speed.
Centrifugal pumps - speed vs. torque curve
The torque can be expressed as
T = k n2                                   (1)
T = torque (Nm, lbf ft)
k = constant
n = pump speed or velocity (rpm)
With the discharge valve closed the torque amounts to 30 - 50 % of the nominal torque at full speed.
Full Load Torque
The torque at full load can be calculated as
T = 30 P / (π n)                                  (2)
T = torque (kN m)
P = power (kW)
