Hydraulic Cylinders - Volume Displacement
The volumetric displacement of hydraulic cylinders.
The volume displacement of a hydraulic cylinder can be calculated as
q = A s / 231                                     (1)
q = volume displacement (gal)
A = cylinder area (in2)
s = cylinder stroke (in)
  • 1 in (inch) = 25.4 mm = 2.54 cm = 0.0254 m = 0.08333 ft
  • 1 in2 = 6.452 cm2 = 6.452×10-4 m2 = 6.944×10-3 ft2
  • 1 gal (US) = 3.785×10-3 m3 = 3.785 dm3 (liter) = 0.13368 ft3
Hydraulic cylinder - volume displacement graph
Example - Hydraulic Cylinder and Volumetric Displacement
A 4" cylinder with a cylinder area 12.57 in2 makes a 30" stroke. The cubic displacement can be calculated as
 q = (12.57 in2) (30 in) / 231
    = 1.63 gal
