Hot Air Balloon Lifting Force Calculator
Calculate the lifting force of a hot air balloon based on temperature difference, air density, and balloon volume. Includes formulas, explanations, and practical applications for aeronautics and physics.
Air Balloon - Hot Air Lifting Force
The lifting force from a hot air balloon depends on the density difference between balloon air and surrounding air, and the balloon volume. The lifting force can be calculated as
Fl = V (ρc - ρh ) ag                                        (1)
Fl = lifting force (N, lbf)
V = balloon volume (m3, ft3)
ρc = density cold surrounding air (kg/m3, slugs /ft3)
ρh = density hot balloon air (kg/m3, slugs /ft3)
ag = acceleration of gravity (9.81 m/s2, 32.174 ft/s2)
Example - Lifting Force created by a Hot Air Balloon
A hot air balloon with volume 10 m3 (353 ft3) is heated to 100 oC (212 oF) .   The temperature of the surrounding air is 20 oC (68 oF). The air density at temperature 100 oC is 0.946 kg/m3 (0.00184 slugs/ft3) and the air density at temperature 20 oC is 1.205 kg/m3 (0.00234 slugs/ft3) .
Fl = (10 m3) ((1.205 kg/m3) - (0.946 kg/m3)) (9.81 m/s2)
= 25.4 N
Weight - or gravity force - can be calculated as
Fg = m a                                       (2)
Fg = weight - gravity force (N, lbf)
m = mass (kg, slugs)
Since lifting force of a flying air balloon equals weight (Fl = Fg ) - the lifted mass can be expressed by combining (1) and (2) to
m = Fl / ag
= (25.4 N) / (9.81 m/s2)
= 2.6 kg
The calculation of lifting force can be done in Imperial units as
Fl = (353 ft3) ((0.00234 slugs/ft3) - (0.00184 slugs/ft3)) (32.174 ft/s2)
= 5.7 lbf
Hot Air Balloon - Specific Lifting Force
Specific lifting force (force per unit air volume) created by an hot air balloon - balloon temperature vs. surrounded air temperature - are indicated in the charts below.
SI - units
Imperial Units
Hot Air Balloon - Specific Lifting Force - Imparial Units
Example - Specific Lifting Force from a Hot Air Balloon
Hot Air Balloon - Lifting Force Example
If the balloon temperature is 60 oC and the surrounded temperature is -20 oC - the chart indicates a specific lifting force
3.3 N/m3
This calculator can be used to calculate the lifting force of a volume with lower density than surrounding air.
