Fans - Noise Power Generation
The empiric expressions below can be used to indicate generated Sound Power Level from fans.
Note! - Exact Sound Power Levels should be obtained from manufacturers data.
Sound Power Level - SI-units
LN = 67 + 10 log(S) + 10 log(p)                              (1a)
LN = 40 + 10 log(Q)+ 20 log(p)
(1b)
LN = 94 + 20 log(S) - 10 log(Q)
(1c)
LN = sound power level from fan (dB)
S = rated motor power  (kW)
p = fan static pressure  (Pa, N/m2)
Q = volume discharged (m3/s)
Fan - sound power noise vs. volume flow and static pressure - chart
Download and print Fan - Generated Sound Power vs. Volume Flow and Static Pressure chart
Sound Power Frequencies
Sound power level in the octaves can be calculated by adding the values below to the sound power level calculated in the expressions or diagram above.
Fans - Noise Power Decibels to add (dB)
Fan Type
Octave (Hz)
631252505001000200040008000
Centrifugal fan, backward-curved blades -4 -6 -9 -11 -13 -16 -19 -22
Centrifugal fan, forward-curved blades -2 -6 -13 -18 -19 -22 -25 -30
Centrifugal fan, straight radial blades -3 -5 -7 -7 -8 -11 -16 -18
Axial fan -7 -9 -7 -7 -8 -11 -16 -18
Sound Power Level - Imperial units
LN = 90 + 10 log(s) + 10 log(h)                         (2a)
LN = 55 + 10 log(q) + 20 log(h)
(2b)
LN = 125 + 20 log(s) - 10 log(q)
(2c)
s = rated motor power (hp)
h = fan static head (inch water gauge)
q = volume discharged (ft3/min)
Maximum Discharge Velocity from Fans for Quiet Operations
The discharge velocity from fans should be kept within certain limits to avoid noisy operations.
Fans - Maximum Discharge Velocities (m/s)
ApplicationSupply SystemExhaust
System
Sound studios, churches, libraries 4 - 5 5 - 7
Cinemas, theaters, ballrooms 5 - 7 6 - 8
Restaurants, offices, hotels, shops 6 - 8 7 - 9
ACMA Certified Sound Levels
Fans - Certified Sound-Power Levels (dB)
Octave Band (Hz)Fan 1Fan 2Fan 3Fan 4
63 117 113 120 101
125 118 116 113 98
250 109 111 111 107
500 106 106 107 120
1000 103 103 103 116
2000 97 98 98 114
4000 94 95 93 109
8000 92 92 88 105
