Evaporative Cooling
Evaporative cooling tutorial.
In principle - the basic evaporating cooling system use only water and a blower to cool circulated air.
When warm, dry and unsaturated air is pulled through a water-saturated medium - water evaporates from the medium to vapor in the air. The evaporation energy comes from the air which is cooled down.
  • air humidity increase - and air temperature decrease
Evaporation differs from boiling and can be accomplished at a temperature lower than the boiling temperature of water because it occurs at the liquid-vapor interface.
Evaporative cooling can be implemented with
  • direct evaporative systems
  • indirect evaporative systems
  • hybrid systems with indirect and direct evaporative cooling units
Direct Evaporative Cooling Systems
In a direct evaporative cooling system - outside air is pulled through a water-saturated medium (typical cellulose) - or air is sprayed with water - and cooled by evaporation. The cooled air is circulated by a blower.
Moisture can be added to the air stream until saturation.
The Direct Evaporative Cooling Process in a Psychrometric Chart
Air at with dry bulb temperature 70 oF and relative moisture 60% (state A) is cooled down (state B) by evaporating water. The process is indicated in the psychrometric chart below.
direct evaporative cooling of air psychrometric chart
With 100% humidification of the air - the dry bulb temperature will approach 61 oF.
The Direct Evaporative Cooling Process in a Mollier Diagram
Air with dry bulb temperature 30 oC and relative moisture 60% (state A) is cooled down (state B) by evaporating water. The process is indicated in the Mollier diagram below.
direct evaporative cooling of air mollier diagram
With 100% humidification of the air - the dry bulb temperature will approach 23.5 oC.
Indirect Evaporative Cooling Systems
In the indirect evaporative cooling system a secondary air stream is cooled down by evaporating water. The secondary air stream is then used to cool down the primary air in a heat exchanger.
Moisture is not added to the primary air and
  • the dry bulb temperature is reduced
  • the wet bulb temperature is reduced
  • relative humidity is increased
  • specific humidity is unchanged
Indirect Evaporative Cooling Process in the Psychrometric Chart
Air at state A with dry bulb temperature 70 oF and relative moisture 60% (state A) is cooled down to state B by a secondary air stream cooled by evaporating of water. The process is indicated in the psychrometric chart below.
indirect evaporative cooling of air psychrometric chart
With 100% humidification of the secondary air the dry bulb temperature of the primary air approaches 70 oF. The relative humidity of the primary air approaches 83%.
Indirect Evaporative Cooling Process in the Mollier Diagram
Air at state A with dry bulb temperature 30 oC and relative moisture 60% (state A) is cooled down to state B by a secondary air stream cooled by evaporating water. The process is indicated in the Mollier diagram below.
indirect evaporative cooling of air mollier diagram
With 100% humidification of the secondary air the dry bulb temperature of the primary air approaches 23.5 oC. The relative humidity of the primary air approaches 86%.
Hybrid Evaporative Cooling Systems
Direct and indirect evaporating cooling units can be combined together in hybrid systems with serial connected indirect and direct evaporative units. In addition evaporation units can be combined with more energy consuming DX (Direct eXpansion) compressor cooling units.
Benefits of Evaporative Cooling Systems
Evaporative cooling systems
  • can be economical since the required size of a DX compressor cooling system can be reduced. Evaporation units reduces DX systems run time
  • can be more environmentally friendly than a DX system since they don't contain refrigerants
  • can be more effective than DX systems at higher temperatures
Note! - be aware that any water system with an operating temperature between 69 oF (20.5 oC) and 122 oF (50 oC) is a potential legionella source.
