Resistors - Color Codes Calculator
Color codes for fixed resistors - values and tolerances - online calculator.
electrical resistor color codes
Color codes for fixed resistors:
ColorSignificant
Figures
MultiplierTolerance
Silver 10-2 +/- 10%
Gold 10-1 +/- 5%
Black 0 1
Brown 1 10 +/- 1%
Red 2 102 +/- 2%
Orange 3 103
Yellow 4 104
Green 5 105 +/- 0.5%
Blue 6 106 +/- 0.25%
Violet 7 107 +/- 0.1%
Grey 8 108
White 9 109
None +/- 20%
Four Band Fixed Resistor
Two first bands (first band is the one nearest the end of the resistor) indicates the value, the third indicates the multiplier and the fourth indicates tolerance.
Example - Value Four Band Fixed Resistor
A resistor with the four color bands
yellow - violet - orange - red
    4   -    7    -  103   -   +/-2%
has a value of 47 kΩ with tolerance +/- 2%.
Four Band Resistor Calculator
Band 1 Band 2 Multiplier Tolerance
Resistors - Standard color codes
Download and print Resistors - Standard Colors Codes table
Five Band Fixed Resistor
Three first bands (first band is the one nearest the end of the resistor) indicates the value, the fourth indicates the multiplier and the fifth indicates tolerance.
Example - Value Five Band Fixed Resistor
A resistor with the five color bands
red - yellow - white - orange - brown
 2   -    4     -   9    -  103   -    +/-1%
has a value of 249 kΩ with tolerance +/- 1%.
Five Band Resistor Calculator
Band 1 Band 2 Band 3 Multiplier Tolerance
