Decibel
Logarithmic unit used to describe ratios of signal levels - like power or intensity - to a reference level.
The decibel is a logarithmic unit used to describe the ratio of a signal level - like power, intensity or amplitude - to a reference level.
  • the decibel express the level of a value relative to a reference value
Two types of decibel are normally used:
  • for power ratios - dB is defined as ten times the logarithm in base 10
  • for amplitude ratios - root power quantities - a change in amplitude by a factor of 10 corresponds to 20 dB change in level
Decibel Definition - Power Ratios
The decibel level of a signal can be expressed as
L = 10 log(S / Sref)                (1)
L = signal level (decibel, dB)
S = signal - intensity or power level (signal unit)
Sref = reference signal - intensity or power level (signal unit)
Decibel is a dimensionless value of relative ratios. The signal units depends on the nature of the signal - can be W for power.
A decibel is one-tenth of a Bel - named after Alexander Graham Bell, the inventor of the telephone.
Note! - the decibel value of a signal increases with 3 dB if the signal is doubled (L = 10 log(2) = 3).
dB vs. Signal Ratio
dBPower Ratio
(S/Sref)
Amplitude Ratio (A/Aref)
-40 0.0001 0.01
-20 0.01 0.1
0 1 1
3 2 √2
6 4 2
10 10 3.162
20 100 10
If the decibel value and reference level are known the absolute signal level can be calculated by transforming (1) to
S = Sref 10(L / 10)                            (2)
Decibel Calculator
Decibel Scale
Example - Lowest Hearable Sound Power
10 -12 W is normally the lowest sound power possible to hear and this value is normally used as the reference power in sound power calculations.
The sound power in decibel from a source with the lowest sound hearable can be calculated as
L = 10 log((10-12 W) / (10-12 W))
    = 0 dB
Example - Highest Hearable Sound Power
100 W is almost the highest sound power possible to hear. The sound power in decibel from a source with the highest possible to hear sound power can be calculated as
L = 10 log((100 W) / (0-12 W))
    = 140 dB
Example - Sound Power from a Fan
Decibel Scale - example fan 120 dB
A fan creates 1 W of sound power. The noise level from the fan in decibel can be calculated as
L = 10 log((1 W) / (10-12 W))
    = 120 dB
Example - Sound Intensity and Decibel
The difference in decibel between sound intensity 10-8 W/m 2 and sound intensity 10-4 W/m2 (10000 units) can be calculated as
ΔL = 10 log((10-4 W/m2) / (10-12 W/m2)) - 10 log((10-8 W/m2) / (10-12 W/m2))
    = 40 dB
Increasing the sound intensity by a factor of
  • 10 raises its level by 10 dB
  • 100 raises its level by 20 dB
  • 1000 raises its level by 30 dB
  • 10000 raises its level by 40 dB and so on
Decibel Ratios - Amplitude Ratios
L = 20 log(A / A ref)                (3)
A = amplitude level (signal unit)
A ref = amplitude level level (signal unit)
